Closed Thread
Old 06-09-2013, 05:38 PM   #7851
jbgroby
jbgroby's Avatar
Re: What did you do to your truck today?
I got the front of the rad support raised and was able to mount the first fender. I was also able to mount the Fender V-6emblem. I have literally waited 13 years to do this!!I need a hanky sniff, sniff.
jbgroby is offline
Old 06-09-2013, 05:50 PM   #7852
JWheeler331
JWheeler331's Avatar
Looks great Jake. How about a picture of the whole truck? I need to get by there and check it out.
JWheeler331 is offline
Old 06-09-2013, 05:53 PM   #7853
markeb01
Senior Enthusiast
markeb01's Avatar
Man that is really pretty. Nice panel alignment!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 06-09-2013, 06:04 PM   #7854
robber grin
Looks AWESOME JB!
Ray and I put the 73 K10 308 posi in the 62 and got it back on the ground once again...
We need to sort out rear shocks now. Monroe 59571's are too short.
Then pinion angle, panhard, lines, etc.
rg / ray~ray
robber grin is offline
Old 06-09-2013, 06:27 PM   #7855
DPowers
One foot in front of the other
DPowers's Avatar
Installed my alum grill and front plate today.
DPowers is offline
Old 06-09-2013, 06:42 PM   #7856
mud.man.rj
mud.man.rj's Avatar
Your paint looks wicked in the sun, cool 66 plate.
mud.man.rj is offline
Old 06-09-2013, 06:49 PM   #7857
DPowers
DPowers's Avatar
Thanks- Originally from the buckeye state
DPowers is offline
Old 06-09-2013, 08:01 PM   #7858
19666Trucker
19666Trucker's Avatar
Got the newly rebuilt radiator(thanks to C.R.S. $65 to seal tanks and rod out and repaint) filled it up with water and good thing after pressure built the weep hole in water pump wants show me it works. Got new pump in and he is running cool and no leaks. Next project cut the springs and open the pipes.
Posted via Mobile Device opps I guess to it was to hot in Scottsdale today
19666Trucker is offline
Old 06-10-2013, 12:06 AM   #7859
TJ's Chevy
TJ's Chevy's Avatar
Hauled some compost with mine to the other garden( ya gotta have two gardens cause ones never enough).
TJ's Chevy is offline
Old 06-10-2013, 12:42 AM   #7860
punkrex
Today I had intentions of upgrading to an HEI distributor. After much debate I dropped some cash on a Skip White dizzy. I went to Napa and picked up 65 vette 80mm plug wires. Checked current timing and it was set by the PO at 0 degree advance- no womder it ran like a dog (283). Verified the vacuum advance at different Rpms and determined it was all in at 16 degrees at around 2800 Rpms. Started to route the new plug wires and determtermined that wires 3&4 were way to short, back to nappy and same PN but correct lengths! but I had to raise the engine off the mounts to get clearance for the new fatter wires. I also spliced into the pink wire from the ignition to provide 12v to the new dizz. After hooking up the new skip white dizzy the truck had a hard time idling- even at 0 degrees and up to eight- it just wouldn't run. Acted retarded. Give it any vacuum FORGET ABOUT IT!!! It would die and usually ended in a poof of exhaust through the carb. Tried another coil(MSD) and it seemed to run worse... Verified plug wires to no avail. I eventually went back to the old points Delco Remey Dizzy and it purred like a kitten. Advanced timing to a total timing of 32- could advanced a more I think but for now it's much better. Gonna call skippy blanco tomorrow and have them send me a new dizzy cause I'm pretty sure something is a wry with this one. Eight hours later...
punkrex is offline
Old 06-10-2013, 11:44 AM   #7861
Blue_Aura
Blue_Aura's Avatar
After tons of scraping, wire brushing, power washing and repeating all steps several times, I got the front frame and suspension all painted.
Current Vehicles:
'62 C10 - 350 (current project), '03 Tahoe (C Series)
Some Past Projects:
'69 Nova - 350 , '70 1/2 Camaro Z28 - LT1 350, '73 K20 Full-time 4x4 - 400 SB, '77 1/2 Camaro Z28 - 350, '84 Camaro Z28 - 305, '68 Buick - 430 BB
Blue_Aura is offline
Old 06-10-2013, 12:27 PM   #7862
61K10
61K10's Avatar
I decided to paint my truck myself--well maybe not the hood (that's all you can see while driving--right) grill and grill shell. will work my way to the big stuff.
1961 chevy K10
my build is------------61K10 build
61K10 is offline
Old 06-10-2013, 08:05 PM   #7863
robber grin
^^ Looks nice - like the color too ^^
I figured out my back shocks and put them on the 62.
rg
Old 06-10-2013, 11:48 PM   #7864
endlessearth
endlessearth's Avatar
I love that color.
endlessearth is offline
Old 06-11-2013, 12:07 AM   #7865
64c20crewcab
64c20crewcab's Avatar
I did a parts trade for 61 hood grille ans support. Need the headlight bezels if any of ya have a set available, please let me know. Thanks!!
..............................._________
......___________//___[[___{\ _____
...../__(_(O)_)___/____/____/_(O)_/
1964 C20 Long Stepside 3 Door Crew Cab
- Armbruster-Stageway Conversion
Y2K INDN Chief
"ONE OF A KIND, NOT ONE OF THE CROWD"
Aug 2010 - Front end frame cleanup & engine swap done!!!
June 2011 - Rear end bagged
Sept 2011 - Rebuild motor top end
Sept 2012 - Parked and slowly working on it.
Aug 2013 - Front end bagged - finally!
Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas...
Here is my build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=335427
64c20crewcab is offline
Old 06-11-2013, 01:13 AM   #7866
markeb01
Senior Enthusiast
markeb01's Avatar
What a nice achievement. Looks great!
markeb01 is offline
Old 06-11-2013, 09:59 AM   #7867
TJ's Chevy
TJ's Chevy's Avatar
Looking cool!
Old 06-11-2013, 10:00 AM   #7868
TJ's Chevy
TJ's Chevy's Avatar
Thinking of putting the tarp on mine today. It looks like its gonna rain in these parts......
Old 06-11-2013, 10:45 AM   #7869
firefighter736
firefighter736's Avatar
Had some louder exhaust installed yesterday evening!
"All anybody wants is a normal life and a cool car... most people settle for the car" - Christopher Titus
1966 Chevy C10 Pics
Rust to Riding - Pictures of my build
firefighter736 is offline
Old 06-11-2013, 11:08 AM   #7870
Blue_Aura
Blue_Aura's Avatar
Thanks Mark!
Current Vehicles:
Some Past Projects:
Old 06-11-2013, 11:54 AM   #7871
61K10
61K10's Avatar
64c20--there was a set on e-bay------
1961 chevy K10
61K10 is offline
Old 06-11-2013, 08:29 PM   #7872
62 Barnfind
62 Barnfind's Avatar
Installed my new seat cover today.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline
Old 06-11-2013, 09:51 PM   #7873
Blue_Aura
Blue_Aura's Avatar
Very nice! That seat cover and carpet would go perfect with my truck.
Current Vehicles:
Some Past Projects:
Old 06-11-2013, 11:53 PM   #7874
gixxer711
Started the notch.
gixxer711 is offline
Old 06-12-2013, 12:19 AM   #7875
mud.man.rj
mud.man.rj's Avatar
that is a Killer notch, wow I like it.
Closed Thread
