Old 11-23-2003, 11:17 PM   #1
devinfife
switching points to hei
if someone could tell me how to switch from points to hei in a 69 i sure would be much obliged. and if you could tell me what parts i need also that would be great too. thanks!
devin
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
69 c-10. turquoise. 350 motor with 400 trans. long fleet. headers and dual flowmaster exhaust. K & N air cleaner, aluminum wheels and radials, stereo system and a bed liner. Manual drums and manual steering.
Kickin it in Seattle, WA
p.s. i love my longbed. must be a phallic thing.
devinfife is offline   Reply With Quote
Old 11-23-2003, 11:32 PM   #2
skokie
skokie's Avatar
Its not very hard. Unless you do what I did and screw up. If I were to do it over again I would mark everything. And I mean EVERYTHING. Instead of 2-3 hrs it took me about 14 hrs total. Mark where your vacumn advance is, mark where your distributor is. You will need a 12 ga wire to run to your fusebox in the unfused ignition slot. Un hook your old wiring from your coil and starter, you can remove it if you wish or tuck it away somewhere. As far as parts go you will need the hei distributor, rotor, coil, and hei wires. If I missed anything I am sure someone will chime in. Also here is a faw about this.
http://67-72chevytrucks.com/vboard/s...threadid=13698
Very good info there.
skokie is offline   Reply With Quote
Old 11-23-2003, 11:43 PM   #3
rage'nrat638
rage'nrat638's Avatar
SOMEBODY POSTED THIS YESTERDAY
rage'nrat638 is offline   Reply With Quote
Old 11-24-2003, 01:30 AM   #4
jcab
I need more money....
There is a how to in the Faq section that goes through this in detail.
Jay.
'68 LWB C10
'74 Duster ("It's not Rusted out, it's been modified for weight reduction")
'91 Civic
'97 Saturn
'88 Celica AWD turbo (R.I.P.) 273 hp Mustang Killer
jcab is offline   Reply With Quote
Old 11-24-2003, 01:32 AM   #5
jcab
oops, Skokie already said this... I should probably read all the posts before I chime in with my 2 cents
Jay.
'68 LWB C10
'91 Civic
'97 Saturn
Old 11-24-2003, 02:10 AM   #6
lukecp
Formerly yellow72custom
lukecp's Avatar
Also remember to open your plug gap up to .045"
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 11-24-2003, 02:52 AM   #7
gonebad2
Merciless Butcher
gonebad2's Avatar
I was cleaning out my garage the other day and found a box of OEM terminals that are used in the bulkhead connector (firewall side). They come in handy when replacing the original resistor wire. You just pull out the old resistor wire, crimp new wire to the new terminal and slide it back in the bulkhead connector. If you want one, let me know. I would be happy to send one to you.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 11-25-2003, 02:08 AM   #8
jimfulco
http://www.pontiacstreetperformance....onversion.html
jimfulco is offline   Reply With Quote
Old 11-25-2003, 11:04 PM   #9
devinfife
thanks for the help guys. that pontiac article is tits.
devin
Old 11-25-2003, 11:21 PM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
HEI distributors are pointless!
Sorry, had to do it.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
