Old 06-11-2013, 08:34 PM   #1
obijuan
np205 27 spline swap kit
ive got basically what you need to change a ten spline 205 to a twenty seven spline. includes adapter, coupler, and input gear. basic essentials. i have also included the coupler seal, input gear o-ring, as well as the trans side o-ring.
adapter has been cleaned and primed, painted, and cleared. all mating surfaces are very nice. coupler is very smooth and will seal very well. splines are not worn out and fit the coupler very well. no pitting on the bearing side, and are a nice polish. lowered to 150 shipped to lower 48.
obijuan is offline   Reply With Quote
Old 06-13-2013, 01:16 PM   #2
obijuan
Re: np205 27 spline swap kit
Bump. Obo.
Old 06-13-2013, 01:24 PM   #3
Fesser
Fesser's Avatar
Is this what you need to convert a 205 that was behind a manual trans to a 205 that would mate to a th350?
Fesser is offline   Reply With Quote
Old 06-13-2013, 02:09 PM   #4
obijuan
That is right
Old 06-21-2013, 06:47 PM   #5
obijuan
150 shipped.
Old 06-24-2013, 10:15 PM   #6
meathead95
computer illiterate
meathead95's Avatar
How hard is it to change the input gear? Interested inline!
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 06-24-2013, 10:56 PM   #7
obijuan
Lay the case on its face. Take off the rear output housing. Straight up. Be mindful of 15 needle bearings.
pull snap ring off input bearing and off input gear snout. Pull bearing amd pull input gear. Installation is reverse of removal.
