Closed Thread
Old 06-12-2013, 12:53 AM   #7876
gixxer711
Re: What did you do to your truck today?
Originally Posted by mud.man.rj View Post
that is a Killer notch, wow I like it.
It's kp components. As soon as my buddy gets his plasma cutter back from the shop, the bottom piece can go in then final welding. Once it's done, we can start on the 4 link, while I am waiting for my dropmember and control arms!
gixxer711 is offline
Old 06-12-2013, 02:32 AM   #7877
BigDan3131
BigDan3131's Avatar
Well the weather is finally starting to dry out and I can get started on the truck. I have decided to get the Rhino done and the paint on it and next year when I get another tax return the motor and trans and new wheels.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline
Old 06-12-2013, 07:24 PM   #7878
jayoldschool
Moderator
Wire wheeled, primed, painted the beads of my wheels. I'll mount 235 75 15 whitewalls on them tomorrow! Some might be wondering why I didn't do the complete wheel. It wouldn't fit with the truck. They need to be crusty.
jayoldschool is online now
Old 06-12-2013, 09:49 PM   #7879
donthekawguy
donthekawguy's Avatar
I finally got the front tires turned around and started fixing up the bed.
66 shorty
donthekawguy is offline
Old 06-12-2013, 09:57 PM   #7880
Lugnutz65
Lugnutz65's Avatar
I set the engine onto the frame. Gotta get this thing back together.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 06-13-2013, 03:10 AM   #7881
19666Trucker
19666Trucker's Avatar
Got rid of my old 16.5 wheels and got some more common 16's thinking it looks funny, satin black should help
19666Trucker is offline
Old 06-13-2013, 04:25 AM   #7882
WCHLVR
WCHLVR's Avatar
Got tired of the terrible lighting. Swapped out the incandescent sealed beams for some Ecode H4 lenses. These ones I fitted also have city lights built in. Think it makes it look super classy!
WCHLVR is offline
Old 06-13-2013, 07:58 AM   #7883
Downlow2xfo
Downlow2xfo's Avatar
Completely disassembled and cut the frame for the Z notch!
Downlow2xfo is offline
Old 06-13-2013, 12:31 PM   #7884
19666Trucker
Old 06-13-2013, 01:43 PM   #7885
JWheeler331
JWheeler331's Avatar
Changed out the old radiator and put in a new 3 row Alum. Radiator
Did manage to break the fan shroud which was kind of brittle.
JWheeler331 is offline
Old 06-13-2013, 02:14 PM   #7886
vin63
It's Better With Nitro
vin63's Avatar
Emblems and mouldings aligned and mocked up...interestingly, I welded up more than 110 holes (some 2 in. in dis.) in the firewall, floor and various areas in the cab drilled by the previous owner. I had to drill 88 holes for the mouldings and emblems.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline
Old 06-13-2013, 03:04 PM   #7887
anubisani
anubisani's Avatar
PUT A NEW WHEEL IN
anubisani is offline
Old 06-13-2013, 06:49 PM   #7888
donthekawguy
I finally got to work on the tailgate today. I was going to have it blasted and then do the work but decided I have spent too much on the truck this year so I took a wire wheel to it with a drill. Turned out good. ground all the rust off then two heavy coats of rust inhibitor-treatment. I'll finish the coating later if it doesn't rain.
66 shorty
Old 06-13-2013, 07:09 PM   #7889
markeb01
Senior Enthusiast
markeb01's Avatar
That turned out nice. What a lot of work. I hate sanding and stripping more than just about anything else, but sometimes it just has to be done the hard way.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 06-13-2013, 07:59 PM   #7890
TJ's Chevy
TJ's Chevy's Avatar
Picked up my new edelbrock carb today and also painted my alternator bracket.
TJ's Chevy is offline
Old 06-13-2013, 08:05 PM   #7891
gimmy 64
man, you look pretty young to be working on these trucks LOL
gimmy 64 is offline
Old 06-13-2013, 08:15 PM   #7892
anubisani
anubisani's Avatar
DID SOME EXHAUST WORK..... installed headers and mufflers,will and some more pipe later down the, have it end under the bed
Old 06-13-2013, 08:37 PM   #7893
Rac65
I agree sanding and stripping is a real chore. I am in the process of taking my whole truck down to bare metal. It had been painted 5 times over the years counting the original and I didn't think it needed number 6.
Rac65 is offline
Old 06-14-2013, 09:35 AM   #7894
JWheeler331
Hey.....gotta start somewhere.
That is my son. He is 11 but loves trucks and esp driving.
Old 06-14-2013, 05:40 PM   #7895
LVPhotos
LVPhotos's Avatar
Grey primed the front fenders.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline
Old 06-14-2013, 06:57 PM   #7896
Trsmotrhed
Trsmotrhed's Avatar
I have the same radiator and works awesome.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline
Old 06-14-2013, 07:03 PM   #7897
ChrisDollins
ChrisDollins's Avatar
Installed the rear 4" springs today and the 7 blade fan. Also got to follow a new '14 in town. Good looking truck!
Chris
ChrisDollins is offline
Old 06-14-2013, 07:54 PM   #7898
jayoldschool
Moderator
Mounted up a set of 235 75 15 WWs on a set of correct wheels, and managed to press the yoke off my rear driveshaft! A good day. Pics tomorrow.
Old 06-14-2013, 09:00 PM   #7899
Downlow2xfo
Beginning of z notch
Old 06-14-2013, 10:16 PM   #7900
tonythezeek
tonythezeek's Avatar
finished fabing up some trans mounts and sent of the first half of a two piece drive shaft to be made. the trans mounts look horrible and will make better ones later as i'm still learning this whole welding/metal working thing but in the words of someone famous,
"...that'll do pig..."
tonythezeek is offline
Closed Thread
