#26 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Drop springs is 3-5 ok without c notch?
Your truck was originally a 3/4 ton longbed. Longbed, reinforced frame, tool box in bed,... My experience has been with 1/2 ton shortbeds and Early Classic Springs and never a c notch. As a matter of fact, I currently have a Honda Goldwing in the bed of my 1/2 ton shortbed truck and I have driven it no sweat.
#27 |
WTB this ad
I have Early Classic 6" drop springs and it does bottom out from time to time. TX I know you say you have never had a problem with them and your statements had a lot to do with my use of ECE 6" drop springs. That being said I don't doubt you or your statements...but my truck does bottom out from time to time out back.
#28 |
WTB this ad
My 3.5"/6" drop all ECE.
![]() Brian's 2.5"/5" drop all ECE same tire wheel sizes. ![]() 2.5" drop spindles will make you much happier than 3" drop springs in the long run. If you can't afford em...save your money til you can. If I can't change your mind at least buy a set of 3" drop springs from me so I can save you some money. ![]() |
#29 | |
Tot Roddin'
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#30 |
Sorry double post.... just read below
#31 |
I have Early Classic stuff (including dropped spindles) but got the 3 inch springs from CPP. The alignment shop didn't want to put the amount of shims needed for alignment and I ended up buying tubular upper A arms from Brothers that are designed specifically for lowered trucks.
I think it's borderline with 3 inch springs (drop spindles dont affect alignment specs) and it's not to say another alignment shop might be willing to shim it up with longer bolts etc... seems others here have done it. Personally I'd save up to buy an ECE drop kit with everything necessary to do it right... springs, adjustable track bar & shock mount relocators. The truck will drive great with this and an alignment. For your info, I think what I have is as low as you can go without airbags and still have a good ride: 5.5in front 7in rear (C notch mandatory) Last edited by Mondo; 12-24-2008 at 12:14 AM. |
#32 | |
I wish I was a cowboy
![]() Join Date: Apr 2008
I do have some significant weight in that toolbox most of the time, and I also do drive my truck every day, often with a load. No cement or raw steel mega-loads, but my truck definitely has truck duty routinely. I posted in my mini-project thread warnings for C20 owners trying to do what the cool guys do with their half-ton shortbeds do - it's definitely not quite the same. Thanks for the info. Here's a question - with a 4 or 4.5" drop in front, am I the only one with long-tube header problems? I'm working on raising the money to go shorty headers and a drop cross member from ECE so I can tuck the exhaust above the frame all the way down, but in the meantime, is it just me?
-Kris Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway). |
#33 |
Mondo, dude, I love your truck. It's making me want to cut my frame down today and start looking for a short fleet bed!
#34 |
WTB this ad
ECE also told me that their 6" drop coils would leave me with 3" between the axle tube and the frame. I have considerably less clearance than that which could explain why my truck hits.
#35 |
Now that's a stretch! Anyone out there with stock 1/2t springs that aren't sagging after 40 years of haulin' that can take a measurement? I'd bet 7-8" max clearance....suggesting a factory ride gives you 9" clearance would put the rear bumper of the truck high enough to pull a Miata underneath!
-Kris Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway). Last edited by kcjones; 12-24-2008 at 12:10 PM. Reason: Too early for good grammar. |
#36 |
i got a 5 inch spring in the rear, and a heavy rear gas tank and i have an inch between my axle and frame. how are so many people getting away without a c-notch. do you guys drive or load your trucks? i can't put a set of wheels back there without bottoming out on everything, and even unloaded and low tank of gas gives me trouble. i'm getting a c-notch before anything else on my truck.
#37 |
WTB this ad
Factory height springs...I don't know how much clearance...but it's tall.
#38 |
I don't know if I've ever seen such a good lookin' factory ride!
#39 | |
#40 |
X2 man I want a shorty
#41 |
Have lower spindels and 1in drop springs with 4in drop in rear but have a 19gal cell in back along with the battery relocated so figure will add to the drop. may do a weld up c-notch once rolling to see what i am left with or want to drop it more.
69 c-10 BBC ![]() 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles. ![]() |
#42 |
Thanks guys,
I have ECE's rear springs but it's probably lower due to the rear gas tank.... and it doesn't hold much weight in the bed (though the softer springs due make for a nice ride). May get helper airbags in the future... wish they made air shocks for lowered trucks but I guess airbags have taken that role. |
#43 | |
![]() Join Date: Jul 2006
#44 |
WTB this ad
#45 |
TTT
This post fits some of our questions. Now with a few more yrs past looking for updated opinions. Since ECE does not sell c-notch kit I assume I need a CPP c-notch kit to go with ECE 4/6 drop kit. (planning for later swapping to air-ride & bags) Any new warnings or suggestions? Better way that ECE today? Also planning to move to 18-20" wheels later
Bob |
#46 | |
![]() Join Date: Jul 2012
CPP has 2 3" notch kits, a heavier one for towing. Apparently 3" is as much notch as you can install without cutting into the bed. Is this accurate?
#47 |
TTT for 2013 thoughts
Bob |
#48 | ||
Tot Roddin'
![]() To answer all three posts.... I have a 4.5/6" drop on my '69. All the products were purchased from ECE. If you plan on loading your truck down with cement blocks, sand, rock, etc., then you will want to add a c-notch. If you plan on using it for lighter loads, etc., a c-notch will not be required. After 2 years of running my ECE kit, I have bottomed out once when I came off a hwy bridge a little to fast. Other than that, I haven't bottomed out once. The ride is smooth and clean, not rough at all. Only you know what you will use your truck for, but the kit without a c-notch works flawless for us. Here's the specs before and after the ECE kit install and with a wheel change: Before the drop w/ 15x8" ralleys running 235/75 R15's: Driver's Side Front: 33 1/2" Driver's Side Rear: 33" Passenger Side Front: 33 1/4" Passenger Side Rear: 32 7/8" After the drop: Driver's Side Front: 28" Driver's Side Rear: 29" Passenger Side Front: 28 1/4" Passenger Side Rear: 28 3/4" After the drop with 20" Vintec Wheels: Driver's Side Front: 28 7/16"" Driver's Side Rear: 29 5/16" Passenger Side Front: 28 1/2" Passenger Side Rear: 29 5/16" If you are going to run bags, then I would install the notch, air bags w/ schrader valves and run it until you are ready to install the air management kit. If I was going to order any parts I would order the spring drop from ECE and the c-notch from Porterbuilt as it is a two-piece design and much stronger than CPP's IMO. Personally... I wouldn't order from CPP but that is my choice.
#49 |
![]() Join Date: Jun 2012
Bit of an old thread, but relevant. I see a lot of talk about not using a 3"+ spring up front, but looking at the Hotchkis site today they have a 4/6 spring drop available. I'm going full Porterbuilt coilover (when I have enough funds) but for now want to throw some lowering springs in until then. Says they include some parts for use with stock arms, but I'm not 100% sold on it if even 3" is giving troubles. Any input on this?
http://www.hotchkis.net/6772_c10_spo...l_springs.html |
