Closed Thread
Old 06-10-2013, 12:55 AM   #7176
Toxic Orange
Toxic Orange's Avatar
Re: What did you do to your truck today!
We went out and took some pictures of mine at the local feed mill.
Toxic Orange is offline
Old 06-10-2013, 02:03 PM   #7177
Tomahawk30
Tomahawk30's Avatar
Got my new aluminum radiator installed and cleaned up a bit of grease and grime buildup while I had the fan / shroud off. Turned out great and works like a charm! Gave it a good wash and took some pictures last night of the closer-to-finished product (slowly but surely...). I'll get a few posted this evening.
1979 Silverado C10 Shortbox - Photo Album
1977 Silverado K20 Camper Special - Photo Album
1972 C10 Custom Deluxe Highlander - sold
1971 Cheyenne Super Longhorn -sold
1972 Cheyenne Super SWB 4x4 -sold, bought back, sold again... I'm dumb.
1970 Chevy C10 SWB "Sprout" -sold
1972 Cheyenne K20 -sold
1969 GMC Shortbox Stepside 4x4 -sold
1972 GMC Jimmy 4x4 -sold
Tomahawk30 is offline
Old 06-12-2013, 06:35 PM   #7178
Expat_dude
Expat_dude's Avatar
more progress, note going with show deck later so the gas cap will have a closer fit..
1970 Chevy swb, project UGHH!
1987 Grand National
http://s168.photobucket.com/albums/u.../1970%20Chevy/
Expat_dude is offline
Old 06-12-2013, 06:57 PM   #7179
anubisani
anubisani's Avatar
installed headers today got her back up an running , will add mufflers tommorow
here is the link to the video
https://www.facebook.com/photo.php?v...33945653419836
if it looks like all white go to full screen on the video
anubisani is offline
Old 06-12-2013, 08:38 PM   #7180
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Headliner 75% in. It's in, but needs final adjustments and cuts (slots)
for the trim.
Thanks to two Forum Members and a friend of of a Member (Tony G).
And thanks to all for getting the parts to me fast. I really appreciate it.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 06-12-2013, 11:35 PM   #7181
chevy88
chevy88's Avatar
Magwakeenercrew I give you credit doing you own paint job, lots of work, it looks real good and you saved lots of coin.
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline
Old 06-13-2013, 08:04 PM   #7182
54belair
54belair's Avatar
Finally got to the point of having to make a final decision on paint color!
Made my choice and left a substantial donation at the PPG store. Had to be mixed, matched and test sprayed for color, will get it tomorrow.
Now its time to pull my big boy shorts up and get busy!!!
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline
Old 06-13-2013, 10:30 PM   #7183
Toxic Orange
So what color did you go with?
Old 06-14-2013, 12:41 AM   #7184
profe56
Installing a Rochester quad on the 305, tomorrow I'll try to wire up the electric choke, tnight I'm looking for How to do it,
Do you have any suggested????????
profe56 is offline
Old 06-14-2013, 02:26 AM   #7185
magwakeenercew2jh
Ground (-) to any good ground (-); and hot (+) to the wiper (always hot when the key's on) circuit.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 06-14-2013, 01:14 PM   #7186
profe56
Thanks: Just a question; (+) needs a fuse between the choke and wiper.
profe56 is offline
Old 06-14-2013, 01:15 PM   #7187
profe56
Forgot to say is Rochester choke and only has (+) connector.
profe56 is offline
Old 06-14-2013, 02:06 PM   #7188
magwakeenercew2jh
Right.
Listen to Nate. He's the real deal.
I, personally, like the wiper circuit because I wired it for an electric washer...I know the load, and I know where the fuse is.
Also, it fits with my placement (hiding) of the wiring and the exit point to the choke.
Listen to Nate, though. A separate circuit is always the best answer.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 06-14-2013, 02:06 PM   #7189
VWNate1
VWNate1's Avatar
Post Re: Electrical Accessories
Really , you should runa new wire from the unused accessory fuse in the fusebox to the choke heater ~ then use the lowest rated fuse you can that won't blow ~ probably a 10 A. one .
Every vehicle always has built in extra un used fuses for radios and other add ons , be smart and use them , do not overload the original wiring .
To properly set the choke , go out to the rig _early_ in the morning when it's cool out and the engine is stone cold , loosen the screws holding the choke element just until you can turn it by hand , open the throttle with one hand and whilst it's open , slowly turn the choke element until the choke butterfly *just* closes , DO NOT load it ! .
Now , snug up the choke screws and release the throttle & you're all done ! .
To cold start it , depress the throttle to the floor ONCE , release then crank it ~ never touch the throttle when operating the starter on a cold engine .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 06-14-2013, 02:06 PM   #7190
bugmasta
bugmasta's Avatar
sitting in the lobby of Randy's Ring and Pinion having the rear end rebuilt with an eaton posi and 3.73 gears.
68 c20 build: http://67-72chevytrucks.com/vboard/s...d.php?t=358130
Club longbed ...cause girls like'em long!!!!!
bugmasta is offline
Old 06-14-2013, 04:45 PM   #7191
profe56
Thank you Magwa and Nate I'll let you know.
profe56 is offline
Old 06-14-2013, 04:55 PM   #7192
Mister-B
Originally Posted by magwakeenercew2jh View Post
Right.
Where did you get that bracket that holds the two hoses together at the bottom of your picture? I'm trying to find something like that for my heater hoses coming out of the heater core
Mister-B is offline
Old 06-14-2013, 05:11 PM   #7193
magwakeenercew2jh
That's just a clamp. I don't remember where they came from...but it was off of E-Slay, for sure.
Here are some cool ones I just found on a "Google Search":
http://dmpfasteners.com/shop/clamps-...t-clamps-1719/
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 06-14-2013, 05:14 PM   #7194
magwakeenercew2jh
Here ya go.
http://tinyurl.com/l2l4utl
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 06-14-2013, 05:18 PM   #7195
Mister-B
Awesome. Thank you
Mister-B is offline
Old 06-14-2013, 09:58 PM   #7196
Dobster
I replaced my oil diptube on my ls1. Old one broke in half at the "O" ring. I was lucky it didnt fall into the windage tray. $19 part 4 hours of labor...
then went for a nice drive around the lake Blowing my 140psi train horns at the people on the beach and playing frisbie golf.
FUN FUN FUN...
Dobster is offline
Old 06-15-2013, 11:52 AM   #7197
74baggedbug
Installed new manuel air ride valves from dloes for my helper bags.. Got rid if the cheap plastic paddle valves & relocated them from down by my knee to the radio location
74baggedbug is offline
Old 06-15-2013, 01:59 PM   #7198
profe56
Installing temperature gauge, I just want to make sure the engine is not overheating, I couldn't install it on the head because I don't have a 13/16 tool, I can't believe it.
Pd tomorrow fathers day I will work with the choke conection.
Happy Father's day tomorrow in advance
profe56 is offline
Old 06-15-2013, 02:02 PM   #7199
Bhelton
Bhelton's Avatar
Replacing brake lines on my stepsons grandfather's super Cheyenne
Bhelton is offline
Old 06-15-2013, 02:05 PM   #7200
profe56
Forgot to mention I've electric fans and the signal on the original gauge is a red light but when is already hot.
profe56 is offline
Closed Thread
