Old 11-26-2003, 01:55 AM   #1
67stepside
67stepside's Avatar
Question moter mount towers
Do the small block towers go in the front set of holes on the frame? Thanks
67stepside is offline   Reply With Quote
Old 11-26-2003, 03:21 AM   #2
frost89434
frost89434's Avatar
They will also work in the rear set of holes too. Just puts it closer to the firewall. JIM
68 short fleet with 71 front clip 2wd jaguar blue
99 chevy ext cab shrtbed z71 loaded
99 chevy swb fleetside(daily driver)
Sparks, Nevada
frost89434 is offline   Reply With Quote
Old 11-26-2003, 09:18 AM   #3
67stepside
67stepside's Avatar
Thanks alot
Old 11-26-2003, 12:00 PM   #4
jay-dawg
chevelito
jay-dawg's Avatar
Hi Jim,
I was looking to see how the V8 towers would bolt up to the rear. Do I have to drill the bottom hole? Switch the towers or something because it doesnt line up. (btw, it had a L6 originally)
jay
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
Old 11-26-2003, 12:15 PM   #5
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
jay-dawg, You small block towers will not line up in the rear set of holes without drilling. Also if you are going to run an HEI ignition, you don't want to place your engine there anyway. I just puts the distributer too close to the firewall. You have your truck completely torn down, so I would set the engine in the correct possition. (In the forward holes) It will be easier to work on and won't be so obviouse that your truck was formerly a 6 cylinder. The only flies in the ointment would be if you are going to a standard transmission. Because then you will need a V-8 bell housing crossmember in order for it to line up. The other fly is wether or not you go to an automatic or not, when you place the enging in the forward holes you will have to have a longer driveline made. (Well worth it though) WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 11-26-2003, 01:08 PM   #6
jay-dawg
chevelito
jay-dawg's Avatar
Thanks for the info Wes.
I'll be running the LT1 in it with the 4l60e. The shaft needs to be redone anyway since (i think) that the splines on the shaft going into the transmission are wrong. But I think you are right. I'll keep it in the front holes.
Thanks,
Jay
