Closed Thread
Old 06-16-2013, 11:24 AM   #2376
Dan in Pasadena
Dan in Pasadena's Avatar
Re: What Did You Do With Your Truck Today ?
Originally Posted by Denee007 View Post
....Servicing the battery under the truck even with the drop down is a struggle
What's to service? With modern batteries being sealed I don't get the reference? I ask cause I intend to move mine down there. When I still had a generator the voltage regulator was slightly off, overcharged the battery and it puked a little acid on my new finned valve cover. Seriously pissed me off!
As for those "extensions" on the battery Russ? I just cut them off and used the stock hold down frame.
Dan in Pasadena is offline
Old 06-16-2013, 11:57 AM   #2377
dubie
dubie's Avatar
Got the fuel system finished, the cooling system is done, just need to run the tranny cooler lines, new window felts and vent window seals are in. All that's left to do before we fire the engine is to install the plugs, plug wires, exhaust manifolds and hook up the tach so we can break in the cam. But it's fathers day and we are heading to a car show, a well deserved break.
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline
Old 06-16-2013, 12:16 PM   #2378
cwii
Finally finished the title process for a bonded Texas Title. The title came in the mail yesterday!! I hope to get started on my 47 Chevy LB soon.
Chuck
cwii is offline
Old 06-16-2013, 01:26 PM   #2379
Daze57
Daze57's Avatar
dan
i think for some of us older folks (not all of us mind you ) its just a little bit easier to sevice the battery for (watever reason )from the engine bay and not have to clammer around slidin under the truck to get it out .
although i do agree it cleans up the looks of the engine bay . its just a bit more convienent to get to ..........as usuall just my 02 centavos worth
Daze57 is offline
Old 06-16-2013, 04:28 PM   #2380
Russell Ashley
Russell Ashley's Avatar
Dan, I have about five more years of warranty on my battery and I doubt that they would honor it if I cut the tabs on the end off. This type battery is not sealed and has removable caps just like older batteries, although checking the electrolyte level is not something that I regularly do. If I did want to mount my battery under the floor I would get an AGM battery.
Russell Ashley is offline
Old 06-16-2013, 06:05 PM   #2381
mknittle
mknittle's Avatar
I stored up energy for tomorrow. I am going to start on the transmission cross member. I got as far as I can with out mocking up the engine and transmission. at least I am no longer going backwards. at least not that I know of.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline
Old 06-16-2013, 06:33 PM   #2382
crossfire84
crossfire84's Avatar
Chuck
cool, start a thread and remember LOTS of pics!!
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline
Old 06-16-2013, 07:47 PM   #2383
itstheshu
Started it up for the first time in a couple of months to find out the fuel pump is leaking.
itstheshu is offline
Old 06-16-2013, 08:35 PM   #2384
arturo7
arturo7's Avatar
Assembled the rear brakes, installed the rear axle.
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline
Old 06-16-2013, 09:08 PM   #2385
Highsider
Highsider's Avatar
I joined up with several local rods and I drove mine about 55 miles to an annual Father's Day show. Hadn't intended to enter, so I parked several blocks away, when the others called me and said drive around and get checked in.
Left the hood down, but windows and back doors were open for a surprising number of lookers.
On the way down there I noticed the original temp gauge started working, as well as the 2" SW gauge.
Also calculated the run at 9-mpg. Oh, well. This was my first high speed, "distance" run. Had a relaxing, fun day.
Highsider is offline
Old 06-17-2013, 12:54 AM   #2386
Zach B
Zach B's Avatar
i moved mine out of a hole in the ground dug by an armadillo.
Zach B is offline
Old 06-17-2013, 06:28 AM   #2387
lowdownstar
big guy
lowdownstar's Avatar
ok where are the pic's? hope all is well
Ray
lowdownstar is offline
Old 06-17-2013, 07:06 AM   #2388
pvienneau
pvienneau's Avatar
Did the gauges this past weekend.
pvienneau is offline
Old 06-17-2013, 08:49 AM   #2389
mknittle
mknittle's Avatar
Ray
All is well, I thinkYou never know these days
I need to take more pictures though.
Mark
My GMC build.
mknittle is offline
Old 06-17-2013, 08:52 AM   #2390
mknittle
mknittle's Avatar
Mass armadillo migration?
Mark
My GMC build.
mknittle is offline
Old 06-17-2013, 08:58 AM   #2391
mknittle
mknittle's Avatar
Forming a plan of action that will soon be scraped in favor of random acts of fabracation
Mark
My GMC build.
mknittle is offline
Old 06-17-2013, 12:36 PM   #2392
arturo7
arturo7's Avatar
Musta been a huge armadillo.
ever forward
arturo7 is offline
Old 06-17-2013, 03:29 PM   #2393
Daze57
Daze57's Avatar
id like to see that picture ^
Daze57 is offline
Old 06-17-2013, 10:24 PM   #2394
Highsider
Highsider's Avatar
Exclamation Re: What Did You Do With Your Truck Today ?
That is pretty far north, in my book.
Old 06-17-2013, 11:23 PM   #2395
mknittle
mknittle's Avatar
I set the engine back in after welding up the motor mounts. everything fit really well the first time.then I cut out some parts for the transmission cross-member.
Mark
My GMC build.
mknittle is offline
Old 06-18-2013, 01:03 AM   #2396
OrrieG
OrrieG's Avatar
Armadillos rock. We lived on a farm when we were in Texas and at night they would come around and knock over the trash cans. Not afraid of anything. There was one that was road kill and after 6 months by the side of the road it the shell was still intact. Wife wouldn't let me keep it...
OrrieG is offline
Old 06-18-2013, 06:39 AM   #2397
lowdownstar
big guy
Now that is what i call nice work my friend!!! looking good
Ray
Old 06-18-2013, 07:44 AM   #2398
focusedontheprize
focusedontheprize's Avatar
Busy past weekend, but it was good. Exhaust, finished the wiring and odds and ends. Trying to get plates for it this week to take it for a spin (took it for a spin around though).
It has been raining a ton in upstate NY so I actually don't feel bad that it wasn't on the road yet.
focusedontheprize is offline
Old 06-18-2013, 08:48 AM   #2399
mknittle
mknittle's Avatar
Ray
Thanks Ray, I had to do the left one{the part that bolts to the block} a couple times to get it to where It looked OK. the problem is there is a step where it mounts to the block. There had to be three angles cut into the square tube at odd ball angles. But It was fun and looks a lot better than the stock clam shells I started with. And was cheaper
Mark
My GMC build.
mknittle is offline
Old 06-18-2013, 08:56 AM   #2400
mknittle
mknittle's Avatar
(took it for a spin around though). Isn't that such a good feeling
I know that feeling. It seems like every time I bought a motorcycle the rainfall was above average
Mark
My GMC build.
mknittle is offline
Closed Thread
