Old 06-08-2013, 03:50 PM   #26
jayoldschool
Moderator
Re: Vinegar for rust removal
Here's the thread, check out the pics, they are amazing!
http://www.garagejournal.com/forum/s...t=vinegar+salt
jayoldschool is offline   Reply With Quote
Old 06-12-2013, 04:44 PM   #27
Rich 5150 69
Rich 5150 69's Avatar
Thanks Jon ....I put my crusty lower rear shock mounts in it for four days, didn`t touch them, took them out, not to shabby for 50 years of rust...I will neutralize with baking soda before paint...
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 06-12-2013, 07:31 PM   #28
XtechX
XtechX's Avatar
If you use the POR 15 stuff, this vinegar solution will take the place of the metal prep they say you have to buy. Alot cheaper too.
Opportunity usually comes disguised....As hard work!!!
XtechX is offline   Reply With Quote
Old 06-14-2013, 11:31 AM   #29
1963c-10
1963c-10's Avatar
Heres the 2nd batch of parts I've done. Rear brackets for stepside tail lights. 4 days soak time, 2-3min wire brushing and a baking soda soak for 30 minutes to neutralize the vinegar soak.
One note I will add is that I do not use the salt mixed into the vinegar, but I do not have that black tarry slag to clean up either that you see with the salt/vinegar solution. I just use straight vinegar and then soak in a baking soda/water solution to clean/neutralize the process. Im equally happy with the 2nd batch of parts, and will be doing tailgate chains for the matching trailer project next. Pics to come
As you can tell, just a little paint left that will come off easily enough by hand and some 60 grit. Will be getting self-etching primer tonight, then sprayed after my next set of parts are ready.
1964 Short bed trailer
Old 06-14-2013, 06:47 PM   #30
bubba327
HOW long until spring??
bubba327's Avatar
another way to beat rust is the battery charger and wash soda method but this way with the vinegar looks pretty darn easy!!
Here is a link to an old thread on electrolysis and rust removal
http://67-72chevytrucks.com/vboard/s...d.php?t=385635
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 06-15-2013, 05:04 AM   #31
Rich 5150 69
Jon you really think you`ll need the etching primer, I would think the vinegar should have etched as is maybe a epoxy primer would be good enough.....
By the way I had talked with an old restorer, well older than me, anyways he used to use vinegar all the time until somebody had told him about citric acid, now he uses it exclusively, he reason being he can up the strength, he normally uses a pound per gallon, but that gallon is used a long tme before he discards it, and it don1t smell as bad as the vinegar, he buys it in bulk 5 lbs at a time...http://www.wkfinetools.com/trestore/...itricacid1.asp
Old 06-15-2013, 11:13 AM   #32
1963c-10
1963c-10's Avatar
hmm, ill check that out. the etching primer is probably overkill, but its what i currently have on hand
Old 06-15-2013, 11:23 AM   #33
1966FLEETSIDE
1966FLEETSIDE's Avatar
rustbelt no, but simply just dipp it in a pool full of vinegar. lol
1966FLEETSIDE is offline   Reply With Quote
Old 06-15-2013, 06:59 PM   #34
bighunting
What do you guys think about putting brake drums in vinegar (or citric acid)? Do you think it would damage the surface that contacts the brake shoe? Any other suggestions for removing rust from brake drums? Thanks
bighunting is offline   Reply With Quote
Old 06-15-2013, 09:48 PM   #35
1963c-10
1963c-10's Avatar
worst case you can always dip then and take them to the machine shop
Old 06-16-2013, 09:27 AM   #36
Rich 5150 69
Brake drums might be better sand blasted, at least you can mask off the shoe area, if they are scored bad enough it wouldn`t matter you would turn the drums anyway.
Old 06-16-2013, 02:00 PM   #37
concretekiller
Quick question; I have a little rust on my headlight bezzels on my '65 from the 3 screws that are used to hold them on. From reading this, the vinegar will remove the chrome or damage it. How can I clean the rust off and not damage the chrome?
concretekiller is offline   Reply With Quote
Old 06-16-2013, 02:09 PM   #38
jayoldschool
Moderator
The headlight bezels aren't rusted, that is just a stain from the rust from the screws. A little compound will take the stain off without damaging the bezel. I like Meguiar's Ultimate Compound, but there are a hundred things that will work. Nevr-Dull will do it, too.
Old 06-16-2013, 02:13 PM   #39
concretekiller
I was actually just about to ask if never full would work, I've used that before on wheels. Thank you Jayoldschool!
Old 06-16-2013, 02:33 PM   #40
1963c-10
1963c-10's Avatar
are the bezels aluminum or steel? mothers has a great aluminum polish also. i have used the never dull also w/good results
Old 06-16-2013, 04:02 PM   #41
jayoldschool
Moderator
Yes, of course my advice only applies to the aluminum bezels!
Old 06-16-2013, 04:47 PM   #42
concretekiller
It helped a little, but didn't get the rust completely off. I dont believe mine are aluminum though.
Old 06-17-2013, 08:20 AM   #43
1963c-10
1963c-10's Avatar
[QUOTE=concretekiller;6126398]It helped a little, but didn't get the rust completely off. I dont believe mine are aluminum though.
Does a magnet stick to them?
Old 06-17-2013, 10:48 AM   #44
jayoldschool
Moderator
Those look like plated steel to me. Naval Jelly will take that rust off, but the plating is damaged.
Old 06-17-2013, 09:37 PM   #45
concretekiller
The headlight bezels are chrome. The turn signal bezels are aluminum though. Working on polishing those now. Also may have found an aluminum grill and bezels on craigslist!
Old 06-19-2013, 08:59 PM   #46
richards72chevy
richards72chevy's Avatar
A little bit off topic but I used to work with an older guy.He said he suffered from kidney stones when he was younger.Went to the doctor and the doc told him to drink a couple of shot glasses full of vinegar once a month or any time he had kidney pains.He said he hasn't had any problems since the 60's.
richards72chevy is offline   Reply With Quote
Old 06-20-2013, 04:59 PM   #47
ChefCy
ChefCy's Avatar
Originally Posted by rustbelt View Post
Great information, thanks.
Any ideas on how many gallons of vinegar it would take to submerge a 61' stepside? lol
that made me laugh!!!!!! lol
ChefCy is offline   Reply With Quote
Old 06-20-2013, 08:16 PM   #48
Lugnutz65
Lugnutz65's Avatar
Some kidney stones form in an alkaline pH urine. Other kidney stones form in an acidic pH urine. Drinking vinegar (a weak acid) will NOT likely affect the pH of urine. After drinking, the vinegar mixes with stomach acid, which is about as acidic as things can get in the body. There are lots of OTHER things that affect the pH of urine, so I think vinegar should be exclusively reserved for cooking and rust removal. Just sayin'.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 06-22-2013, 07:57 AM   #49
richards72chevy
I never had a kidney stone so I would not know.The guy realy believed in it.Some of the older people are realy set in there ways though.
Old 06-28-2013, 12:45 PM   #50
concretekiller
It works! Headlight buckets on the way to powdercoat
