Old 06-11-2013, 06:14 PM   #1
fostrem
Final tranny instal questions
So I got a rebuilt 350 under my 1976 k10, and ive got a few last questions that I know will make me sound like an idiot.
What does the dipstick bolt onto?
How does the selector attach to the chassis? I'm confused as to how it is held in place with the spring and all.
Thanks in advance
fostrem is offline   Reply With Quote
Old 06-11-2013, 06:23 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Final tranny instal questions
The dipstick should bolt to the top passenger side bolt on the trans bell housing
Your selector should go int the bracket as follows
1. Have the spring on the selector shaft then attach the ball pivot and install into the bracket and then slide into the trans gear selector. And install cotter pin. That should have you set up ready to rock
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 06-14-2013, 12:03 PM   #3
raceman6135
Dino burner
raceman6135's Avatar
Typical linkage diagram:
raceman6135 is offline   Reply With Quote
Old 06-14-2013, 04:39 PM   #4
fostrem
Thanks for the replies. I saw that diagram earlier the problem was i was missing the ball joint thing. quick stop at the pick n pull and everythings good.
Thanks again guys
Old 06-16-2013, 10:58 PM   #5
78maliburat
The nylon bearing can be replaced by a big block chevy rocker arm ball..just takes a little bit of sanding on the shaft to fit..most parts stores carry them for less than $3.00
78maliburat is offline   Reply With Quote
