Old 06-15-2013, 11:15 AM   #1
R&K's71
Quick Question
I have a 79 Big 10 am I able to use a Dash Gauge Bezel from a earlier model. I like the all black with the chrome rings around the gauges. Do they all fit the same any info would be appreciated.
R&K's71 is offline   Reply With Quote
Old 06-15-2013, 02:10 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Quick Question
Yep - they are all the same ('87 and earlier. '88 and up are different because of the radio).
In fact the Silverado version is just a brushed applique stuck on the same black base part.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 06-15-2013, 02:25 PM   #3
R&K's71
Re: Quick Question
Thank you Keith
Old 06-15-2013, 04:30 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Quick Question
Keith, I do not agree with you. The 83 and earlier interchange, then 84 and up. Remember the difference between the wiper switch...
Tx Firefighter is offline   Reply With Quote
Old 06-15-2013, 06:28 PM   #5
Keith Seymore
Re: Quick Question
Ah -good catch.
You are correct - the wiper switch is different.
I was focused more on uplevel vs low level within a given model year.
K
1979-1986
1986 - 2019
Old 06-15-2013, 06:38 PM   #6
Tx Firefighter
Re: Quick Question
I was hesitant to speak up with a conflicting opinion against "the man".
Keith, hardly a week goes by that I don't want to ask you a question about these trucks. I have a lot of questions about assembly and why GM did certain things.
Old 06-17-2013, 07:34 AM   #7
Keith Seymore
Re: Quick Question
Fire away.
Perhaps we should start a new thread, sort of an "open mic" where people shout out questions and I'll see if I can answer them...
That's the hard part about these trucks (and trucks in general). There is so much proliferation that you really have to be "on your game" to remember all the little nuances.
I can't tell you how often I'll ask an "expert" here at work and get a definitive answer, only to think of some little detail (or have the expert call me back after remembering something) that changes the answer.
K
1979-1986
1986 - 2019
Old 06-17-2013, 08:43 AM   #8
superwade57
Re: Quick Question
To interject.... 73-74 are once again their own... due to wiper switch and headlight switch bezel differences... then 75-80 are different than newer due to the corners being more rounded due to dash pad differences. The older bezels will interchange to.newer dashes And I suppose technically the 81-87 will interchange however you are almost guaranteed to crack corners and if you didn't the fitment isn't proper and I personally wouldn't be happy with the fitment. And I wasn't aware of the later break as.mentioned but it makes sense with the switch from in-dash to on-lever wiper delay controls.
superwade57 is offline   Reply With Quote
