Old 06-17-2013, 09:34 AM   #1
Southern Shaker
Wink Doing the 6.0 lq9 Swap!
So im throwing my rebuild small block 350 an turbo 350 up on the ol CL then going to pick up a 6.0 lq9 and 4l80e for my 71' I have about 1400$ so this will be either a donor pick up I buy or a salvage yard motor. Anyone who has done the swap have any advice ? Any Regrets ? and as far as Wiring What can I do to make it as Easy as possible ? And I hear you can use the stock motor mount brackets ?
Southern Shaker is offline   Reply With Quote
Old 06-17-2013, 10:51 AM   #2
67 chevelle
67 chevelle's Avatar
Re: Doing the 6.0 lq9 Swap!
check this link
http://67-72chevytrucks.com/vboard/s...d.php?t=427417
67 chevelle is offline   Reply With Quote
Old 06-17-2013, 11:49 AM   #3
wgeyer88
Check out the LSX Swap section on the forums, there's more info there than you'll ever need! All the questions you have and haven't even thought of are answered there.
I found it also helps to read through some build threads to get an idea of what works and what doesn't.
As far as engine mounts go, the selection is endless. You can use original V8 stands, 6-cylinder stands, 73-87 V8 stands, or many aftermarket stands. For adapters there are quite a few choices too.
Check out these links:
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
Will
1970 CST10 SWB LQ4/4L80E
2004 Silverado (sold)
2007.5 Dodge Ram 2500
wgeyer88 is offline   Reply With Quote
Old 06-17-2013, 11:51 AM   #4
wgeyer88
FYI, not all combinations of mounts/stands work with all transmissions.
For example: With the 4l80e you cannot use 6-cyl stands with 1" setback plates if you have a low hump floor, the transmission won't clear!
Will
