Old 06-08-2013, 06:53 AM   #951
kart34
Re: Extreme Powder Coating '65 C-10 Shop Truck
It is boiling the fuel after the pump... our new crappy gas with boil at 90 degrees .. fuel temp was 166 ... moving a coolant line and re-routing a fuel line
edited by staff
kart34 is offline   Reply With Quote
Old 06-08-2013, 07:27 AM   #952
coulter
coulter's Avatar
dang i never would have guessed that.. what is heating it up so bad? exhaust, compressors?
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 06-10-2013, 07:22 AM   #953
kart34
The upper coolant line into the intake manifold... and the fuel line out of the mech. fuel pump is 1/4 in. from lower rad. hose.. All plumbed with alum. AN fittings boiling fuel at the 90 degree bends..
edited by staff
Old 06-10-2013, 08:05 PM   #954
cAlvis165
cAlvis165's Avatar
Glad you got it figured out! Hope you get it all fixed, and can enjoy driving it soon!
Success is not final, failure is not fatal: it is the courage to continue that counts. Winston Churchill
DD 2000 Chevy Suburban 4x4/5.3 Vortec/4L60E/4:10s, 18" Escalade rims, Electric fans
Project Dooley One-Ton 4x4 on 38.5s Corn-binder build
cAlvis165 is offline   Reply With Quote
Old 06-17-2013, 07:20 PM   #955
kart34
Does any one know the caster and camber settings for a Dropmember at ride height?
edited by staff
Old 06-18-2013, 08:42 AM   #956
Gmforce
Gmforce's Avatar
The suspension gurus say 0 caster and any where from 3 to 7 camber for cornering depending on what your using it for...daily driving 3 to 5 If I remember the numbers correctly....
Geoff
Gmforce is offline   Reply With Quote
Old 06-18-2013, 05:32 PM   #957
lolife99
67-72 parts collector,…
lolife99's Avatar
I think you have your camber and caster backwards,...
Keith
Convert to disc brakes.
Old 06-24-2013, 02:20 PM   #958
kart34
OK Guys... NEED HELP Please....
Whats wrong with my engine combination on " NO Paint" ???
.030 over 1965 327 2.02 461 heads / 10-1 comp. Speed Pro pistons / full Comp Cams valve train package with a Comp Cams 295 TH7 mutha thumpr cam / Trick Flow Street Burner intake duel plain.
1997 T-56 6 speed with a Richmond posi 4.11 rear gear 31.5 tall tire..
What is wrong??? ... it will not pull 5th or 6th gear.. no low end... not happy with the performance and this TRUCK needs to be In Columbus / Good-Guys this year.. wrong cam ? need more gear ??? Please help..
edited by staff
Old 06-24-2013, 02:29 PM   #959
lolife99
lolife99's Avatar
You might post up in the engine/drivetrain area,...
Keith
Old 06-24-2013, 02:53 PM   #960
DURG
DURG's Avatar
5th is overdrive and 6th is a DEEP overdrive in that tranny correct? Seems to me you are over cammed. Looks like the RPM range for that cam STARTS at 2500 RPM and tops out at 6400. 2500 RPMS in that tranny in 5th gear is going how fast? I have a 383 stroker in my Impala with a 670 cfm carb and a more moderate cam that starts around 1500 RPM's. It only dynos at 394 H.P. but makes 454 ft. lbs of torque. For ****s and grins bring it up to about 4500 RPM in 4th and shift into 5th and see if it will pull then. I just think it is set up for too high of an RPM range. Also, what is the carb? Is the timing right?
1962 Impala SS 383 stroker Tremec TKO 600 Black
1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black
2003 100th Anniversary Road King Classic Silver Black
DURG is offline   Reply With Quote
Old 06-24-2013, 02:59 PM   #961
kart34
We have the Street Demon ( new style by Holley) combo carb/ looks like a Edelbrock / quadrajet deal.. 625 cfm.. We will check the timing ....
Also posted this up on Engine /driveline forum.. thanks..
4 th gear it pulls great... runs best in 4th gear.. maybe just yang it out Blueprint 383 stroker 420 hp is what I need...
edited by staff
Old 06-24-2013, 03:33 PM   #962
jhrusk
sounds like it may not have enough gear and a little too much cam for the 327, a 383 or 400 with a little less cam or more gear might help, something with lower end torque. Just my opinion.
check out SANFORD build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=522019
jhrusk is offline   Reply With Quote
Old 06-24-2013, 03:35 PM   #963
kart34
Yes... looks like a cam and gear swap..
edited by staff
Old 06-24-2013, 03:55 PM   #964
kart34
edited by staff
Old 06-24-2013, 06:19 PM   #965
fastbagged68
fastbagged68's Avatar
That camshaft with the little cubes makes it for higher RPM then advertised. Smaller cam, and more gear with that size rear tire. @ 1800RPM in 6th gear you doing 82mph that is not enough RPM for that motor. 4th gear 2500RPM you are doing 57MPH. You need to switch your rear gear to 4.88 min. or change the tire height.
fastbagged68 is offline   Reply With Quote
Old 06-24-2013, 08:01 PM   #966
creep
Registered Loser
creep's Avatar
Hope you get everything sorted out. After the way my summer has started I really NEED to see your truck in Columbus.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 06-25-2013, 09:11 PM   #967
kart34
thanks Guys... picking up a alum. headed 383 stroker 430hp..457 torque.. that should fix the problem...
heading to Speedway Motors in the early am..
edited by staff
Old 06-26-2013, 03:52 PM   #968
jimmydean
jimmydean's Avatar
If 457 torque won't scoot, I don't know what will. I guess you could always just drop in an LS9.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 06-26-2013, 08:45 PM   #969
kart34
Wink Re: Extreme Powder Coating '65 C-10 Shop Truck
Pretty happy... gotta 383 stroker today from Speedway Motors,built by Blueprint Engines, fresh build 5/22/2013 hp was better than thought 442hp @5600 rpm 445.1 on torque @ 4400 rpm alum. headed straight plugs also... so.. hopefully no exhaust issues, I got a set of Hedman block huggers on it now all ceramic coated... I hope the install goes well.... Roger Burman is painting the short block tonite.. Great crew down there..thank you Lakeside Rods and Rides.. I will have Tiffany post up some pics.soon...
edited by staff
Old 06-28-2013, 09:07 AM   #970
Alvin
Never Done?
Alvin's Avatar
That 383 oughta be sweet!
Are you still running the eBay mustang mufflers? If so, are you happy with them? I'm going to be taking mine to the exhaust shop next week.. finally!
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 06-28-2013, 09:55 PM   #971
kart34
Alvin, Yes still running the mustang mufflers...
edited by staff
Old 06-30-2013, 09:02 AM   #972
kart34
Well, We ran into a little problem.. 327 flywheel not campatable to 383 stroker... gotta order a complete flywheel / clutch combo early Monday AM.. any suggestions who I should call ? Bowler ? I got a 1997 T-56 tranny
edited by staff
Old 06-30-2013, 01:12 PM   #973
DURG
DURG's Avatar
Is your 383 running a 400 type externally balanced crank? Mine had an aftermarket stroker crank and was internally balanced so a regular small block flywheel fit. Why wont the 327 wheel work specifically?
Old 06-30-2013, 06:28 PM   #974
creep
Registered Loser
creep's Avatar
If I remember correctly my 383 needed a 400 balancer and flexplate.
Old 07-01-2013, 10:52 AM   #975
kart34
it has a big balancer on it now.. got Twin Cities Rod and Custom calling Blueprint Engines and Speedway Motors..
edited by staff
'65, c-10, carter hickman designs, extreme powder coating
