![]() Join Date: Nov 2011
Cancelling Cam issue
Just installed my Grant steering wheel into my 70 GMC- used the Grant install kit and new cancelling cam (for tilt wheel) - everything works great except that my right hand directional will not cancel out-- Left hand signal works fine- anyone run into this issue or have an idea what I did wrong? Any help is greatly appreciated-
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: Cancelling Cam issue
Did you knock the little canceling spring in the signal switch out?
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Usually its the canceling spring that the cam hits. Right now mine cancels fine right but won't cancel left.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
#5 | |
When I was troubleshooting mine I pulled the wheel and adapter, then just used the cancel cam to turn in there and see if it would hit. Took a few adjustments to get it to work, and it was fine for a while. Now it hasn't worked on the left in a month or so and I have to take it apart again.
#6 | |
Replaced the canceling springs-- everything working- thanks to all for the suggestions-
Wish I had my Grant install kit.Ordered mine back in April,and today they are telling me it will be the end of July.
84 step side 87 swb |
