Old 06-18-2013, 11:04 PM   #1
1972BackInBlackC10
1972BackInBlackC10's Avatar
Question TH350 vac line needed?
so my question today is, do you need the vacuum line for the th350 that runs to your intake? my friend said you don't need it and iv never heard of this before, its currently off right now but im not driving it as the truck is still being assembled so id like to know if this is a do or a don't before I drive it, I don't want to wreck my trans
also the trans has a stage 2 shift kit and a 2800-3000 stall converter installed
1972BackInBlackC10 is offline   Reply With Quote
Old 06-18-2013, 11:09 PM   #2
Bigdav160
Bigdav160's Avatar
Re: TH350 vac line needed?
If you don't run the line the trans will shift very late and hard.
The vacuum modulator controls the pressure. Zero vacuum means max pressure.
The trans doesn't mind but it will drive like crap.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 06-18-2013, 11:13 PM   #3
1972BackInBlackC10
thanks, ill just hook it up then
