06-17-2013, 10:36 PM | #7926 |
Re: What did you do to your truck today?
On Man that makes a world of difference.
As to holding on the caps, there are two styles of rims, yours has 3 "bumps" on the inner ring your cap snaps down over those. I have the early style with the 3 "clips" on the inside of the ring. I'll try to get a picture later
http://s1299.photobucket.com/user/jb...23904108567829 |
06-17-2013, 11:15 PM | #7927 |
Moderator
Those are the nub wheels. I have a set of the clip ones that came with the truck, too.
06-17-2013, 11:27 PM | #7928 |
06-18-2013, 12:05 AM | #7929 |
Moderator
Thank you, my friend! Couldn't have done it without you!
06-18-2013, 12:24 AM | #7930 |
i haven't posted in a while but i like this thread. i got my new moser girdle diff cover on and just slid my rotors in place on the rear for my disc conversion.
1967 c10 stepside 6.0L 4L80E |
06-18-2013, 12:51 PM | #7931 |
After 4 trips to 4 different parts places, I finally was able to piece together my split lines and get them installed to the dual M/C. I still need to bench bleed the M/C and figure out how to lengthen my pushrods. Then after I paint the booster and M/C, I will have to bleed the brakes. I might just do all the after I install the engine. I just want to see the motor sitting in its rightful place and get it off the engine stand. Lol.
Posted via Mobile Device Posted via Mobile Device
Current Vehicles: '62 C10 - 350 (current project), '03 Tahoe (C Series) Some Past Projects: '69 Nova - 350 , '70 1/2 Camaro Z28 - LT1 350, '73 K20 Full-time 4x4 - 400 SB, '77 1/2 Camaro Z28 - 350, '84 Camaro Z28 - 305, '68 Buick - 430 BB |
06-18-2013, 03:32 PM | #7932 |
Finally ordered the Classic Update wring kit from American Autowire. Ordered it through ez2wire.com for $470 with free shipping. Lots of reading and suggestions from guys on the board and it seems like the best one for what I want to get to eventually and the ease of installation and quality.
Sorry no pictures, but I have been getting a lot done lately, but pictures are stuck on my camera. Need a new cable to connect to the computer. Got bed wood cut and painted, pulled the bed off, and am doing a cheapo Rustoleum paint job for the time being. Have so many other things to do that I don't want this to turn into a 2 year deal and I never drive the truck, sooooo going that route. Still needs plenty of body work, and this will be a "good enough for now" paint job. But my personality has a REALLY hard time doing anything "good enough for now," so I am having real trouble drawing the line. I am sure you all know what I am talking about. |
06-18-2013, 04:43 PM | #7933 |
Senior Enthusiast
Accompanied by one of my grand daughters, took the truck out for a ride and picked up a double pole, double throw momentary toggle switch for the new cutout system. The kits all seem to include a rocker switch would look out of place in my truck.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
06-18-2013, 04:45 PM | #7934 | |
06-18-2013, 06:23 PM | #7935 |
Uh where are you going to fit one more switch in your truck, it the bat moblie already!
06-18-2013, 08:32 PM | #7936 |
Thought about mine today.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
06-18-2013, 08:35 PM | #7937 |
Thanks! That straight pipe gave me a headache after five minutes of idling. That ting is scary somtimes.
06-18-2013, 10:51 PM | #7938 |
Worked on homemade filler panel for my "new" tailgate.
Trying to create a smooth, no letter look. Still have touching up to do but so far so good. Last edited by verdell; 06-18-2013 at 11:05 PM. |
06-18-2013, 11:23 PM | #7939 |
I had to make 2 rivets for the GMC lens. I'll try to post pictures tomorrow. Pop rivets would not work because of the danger of breaking the rare plastic lens and they would stick out too far on the backside which has to be really close to flush. I'll smear some JB Weld just make sure they won't come lose and fill the core with solder. Although aircraft rivets are smooth, you can't beat them down.
06-19-2013, 08:39 PM | #7940 |
With help from a friend, I adjusted the valve lash. Then installed the side covers, dizzy, and then finally the intake/exhaust manifolds. Also had a machine shop heli-coil my exhaust manifold so I could install new exhaust manifold studs.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
06-19-2013, 09:52 PM | #7941 |
Got my z notch welded in and cut 1 1/2 coils out of front springs... Gettin there!
Posted via Mobile Device Posted via Mobile Device |
06-19-2013, 11:06 PM | #7942 | |
Sam |
06-20-2013, 10:44 AM | #7943 | |
Jay
06-20-2013, 03:44 PM | #7944 | |
Senior Enthusiast
Now that it's actually going to happen, I'm realizing the safety cover is going to interfere with easy operation, and with 6 wires needing to go into a small area (the old ashtray housing is still in place) it would be a real pita to modify the existing circuits. So, I found another spot next to the 3 gauge under dash panel that's easy to access and already has an abandoned switch hole in place. It’s a standard chrome metal toggle switch, but its wearing one of the flexible rubber waterproof boots simply to minimize visibility: It’s so stealth it’s hard to photograph:
06-20-2013, 05:55 PM | #7945 |
Found a '61 hood that is in better shape than the one I found before and dug up a set of near mint hood inserts with the amber lenses to finish it off.
Now I just have to drive 600 miles round trip to pick the stuff up and get it home. I'm becoming hood poor. Have an extra 60 GMC and a 61 C10 hood now...... Finished the tune up and I can actually drive the old heap and not have to worry if it will start after parking it. Adjusted the timing, plugs, wires, new rotor and cap and took the 1" riser out from under the carb. Made an appointment with a new body shop guy to talk about the BBW conversion. It never ends.
http://s994.photobucket.com/albums/af62/ScottAz2/ |
06-20-2013, 06:06 PM | #7946 |
Worked on getting the rear down!
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
06-20-2013, 06:07 PM | #7947 |
06-20-2013, 06:08 PM | #7948 |
Hooked up the water heating system on mine today.
06-20-2013, 10:31 PM | #7949 |
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
06-21-2013, 12:20 AM | #7950 |
10 minutes after this pic was taken the front bump stop brackets were lying on the concrete.
Horse Farm Truck also got a new ignition today but that pic isnt sexy. |
