#2426 |
Re: What Did You Do With Your Truck Today ?
the camera will be rollin'. How could I not record and share a moment like that?
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
#2427 |
Picked up fleetside bed from Qksilver outta NC. Perfect sides
Posted via Mobile Device |
#2428 | |
IF there is good metal on either side AND you want to use it I would be putting in long fish plates, not relying on butt welds or small patches. It would be a shame to put in all the effort to restore the truck only to find your effort compromised the first time you hit a swale, railroad track or parking lot entrance a little too fast and find the frame bent in the middle and the truck dodging into the other traffic lane at speed. It's your truck you can do what you want with it, but if safety is compromised someone else may get hurt.
#2429 | |
![]() The plan after that is to take everything off and restore the whole frame in one shot, as soon as I can find an inexpensive place to do it indoors. No garage here at the house. Kills me to leave the thing outside but there's nothing I can do other than cover it. I've got the cleaned up bed pieces in the basement, but I don't think the frame will fit! ![]() Thanks again... |
#2430 |
very nice lookin fleetside bed
#2431 | |
#2432 |
flipped the traction bars to try and get a bigger angle on the traction bars to eliminate clutch chatter. Then loaded the bars against the rear so it would control the spring wrap up.
Helped, didn't eliminate it. Still have to check out the motor mounts and the trans mount for security. played with the toe a little. It drives better. |
#2433 |
Elev8r Man
Ok, so my new tie rods and couplers came in at NAPA and I picked them up for installation this coming week. Great find today, while I was browsing around on a jobsite I am working on, I found rolls of 3/8" jute padding not the cheaper stuff either, this is the higher density stuff for homes(its used and flattened a bit) . Perfect timing as my carpet just came in and is lacking full jute padding. I guess I know what my weekend is going to consist of work wise on the truck.
1955.2 C4 Carry-all / Suburban ![]() 1958 Fleetside SWB ---> 58 Fleetside Build thread 1939 2 door sedan My F.B. project page. |
#2434 |
worked on fuel tank install sliced my arm a bit on a sharp edge, had enough and took my wife to a brewers game today!
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
#2435 |
http://m.youtube.com/#/watch?v=G6nqu...%3DG6nquIo_GFs
Fired the engine for the first time. Posted via Mobile Device
#2436 | |
![]() ![]() Join Date: Nov 2008
#2437 |
Elev8r Man
That sounds SWEET dubie.
I wired the truck today all except the ign. Switch, light switch. Since I was under truck running all my engine wiring I though I would hook up my new vacuum booster S/S line to save the effort since I was already down there and low behold as I pushed the #&$%3+ plug into the vacuum booster, the rubber seal that holds it in falls INSIDE THE BOOSTER. ![]() I guess now I am going to have to drop the master cylinder and booster and hopefully I can fish it out of there. It really feels like someone doesn't want me to drive this truck ![]() ![]() Well, thats my 2 steps forward and 1 back for the week. My lesson learned was " I need to slow down'' and be patient.
#2438 | |
#2439 |
Elev8r Man
Thankfully one of my buddies had cancelled for today, otherwise the master cylinder would have been full because we were going to fill and bleed the entire brake system today as well as fill all the fluids in the truck. I am happy NOW that my brakes werent filled and bled today only because it would be a big mess and having to bleed the system again wouldnt be very fun at all. Although I did fill all the other fluids afterwards.
1955.2 C4 Carry-all / Suburban ![]() 1958 Fleetside SWB ---> 58 Fleetside Build thread 1939 2 door sedan My F.B. project page. Last edited by fabguy; 06-22-2013 at 10:43 PM. Reason: spelling |
#2440 |
Weld, grind, plastic on the door holes left over from the one piece window install. Set up a stand for my drill press, no more kneeling to drill!
#2441 |
Drove it to the local Saturday night car show and put it in the show. Determined that my toe was out, so tomorrow, I will fix that. Met another Corvette guy, and we talked fuel injection for hours.
#2442 |
#2443 |
Elev8r Man
Today I was allowed to go to the shop to work on my truck, my 10yr old daughter told my wife that WE need to get the truck done because we will miss car shows if we don't have it finished soon. She washed away all the over splatter from the buffing and polishing compounds. She cleaned 90% of the truck, meanwhile I finished the light switch and Ign switch wiring as well as starting gluing down the carpet and cutting holes for brake pedal etc. Then we went to lunch and Barnes & Noble cause she wanted a custom classic truck magazine....
#2444 |
![]() Join Date: Jun 2011
Put my fresh heavy duty built tranny in Big Bertha......it works great just my wallet is complaining
___________________________ 1959 Apache Short Fleetside, 1959 Apache NAPCO Long Stepside, 1957 3100 with 59 fleetside bed 1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370 1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF 1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker Big Bertha Build |
#2445 |
fabguy, I think your daughter is a keeper!
![]() You guys that rewire a truck in an hour and rebuild an engine in an afternoon kinda piss me off! ![]() ![]() I had bigger plans but all I got done was to wash mine, razor some overspray off the window, and went to OSH for a couple bed bolts - since I've been driving mine for 1-1/2 years with only vice grips holding the bed on! I also did a trial spray of my lower interior door with spray undercoating to kinda camouflage the less-than-I'd-hoped-for fit up of my speaker hole repairs. Jury is out on whether I'll leave it. |
#2446 | |
Elev8r Man
Actually landing the wires took me about 2 hrs. Routing, soldering, shrink tubing, strapping, and installing it almost hidden took well over 24 hrs. I still have to wire the speedometer and the torque conv lock out thing. Hopefully going to fabricate my battery box today. Posted via Mobile Device
#2447 |
Yesterday I bought a bag full of cheap bolts to mock up the front sheet metal.
I can't get stainless bolts here by the pound so I will use the $2.50 a pound grade 2 for mock up. |
#2448 |
I've also been doing the mockup, 53/s10 cab height and front sheet metal,rad support. Everything lined up pretty good once I raised the front. Front cab mounts are clamped in place. Still need to make the rear mounts. My welding is getting better. Also been working on the guages, trying to use the s10 guages. Need to take more pictures.
#2449 |
Nutin, got roped into carb work on the other "new" car...
#2450 |
Nothing. it's raining and my frame outside is under a tarp.
