06-20-2013, 10:20 PM | #1 |
will ZJ jeep springs work to lower 67` rearend?
I know you guys hate seeing these trucks lowered this way. but with a 3 month old my budget is extremely tight. these springs were given to me. this is not my DD so hauling a load is not an issue. thank you guys in advance for any comments made. also my truck is 67` swb 2wd.
06-20-2013, 11:00 PM | #2 |
Moderator
Re: will ZJ jeep springs work to lower 67` rearend?
I read that they were supposed to lower your truck around 4" in back. They didn't lower it at all for me, was a waste of money. They are not any shorter, just less of a rate and flimsy, made the truck bounce. Since you have a set, try them out and see if they work for you.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
06-21-2013, 03:32 AM | #3 | |
Posted via Mobile Device |
06-21-2013, 05:01 AM | #4 |
I have these springs on my truck....yes they may be flimbsy as far as hauling anything in your bed...but on a budget they work great....my truck rides pretty smooth....they were passed down to me by a fellow member on here...good luck to ya..
06-21-2013, 07:17 AM | #5 |
They may or may not lower it at all and don't plan on carrying anything in the back. You are MUCH better off saving $99 and buying some CPP springs.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
06-21-2013, 09:38 AM | #6 |
The springs I have, have the pigtail at one end and a bigger opening at the other end. Are these the correct springs to use? Thanks again for comments and advice
06-21-2013, 09:54 AM | #7 |
For the rear u need pigtail on each end the front has it on 1 end,I run jeep springs in the rear dropped it 3 to 4".I't is a little soft in back, I did haul about 400lbs of tile in it and it rode like a caddy and didn't squat down but maybe a 1".
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
06-21-2013, 10:35 AM | #8 |
+1
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
