Closed Thread
Old 06-21-2013, 01:35 AM   #7951
Trsmotrhed
Trsmotrhed's Avatar
Re: What did you do to your truck today?
Painted my bed sides flat black for now.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline
Old 06-21-2013, 03:30 PM   #7952
19666Trucker
19666Trucker's Avatar
Originally Posted by endlessearth View Post
10 minutes after this pic was taken the front bump stop brackets were lying on the concrete.
Horse Farm Truck also got a new ignition today but that pic isnt sexy.
Funny my c20 got it two, a coil, plugs, and reman dizzy, and clean ed the wires behinf the cluster and alternator hook up for remote volt reading. Some day I like see the farm truck
19666Trucker is offline
Old 06-21-2013, 06:05 PM   #7953
endlessearth
endlessearth's Avatar
[QUOTE=19666Trucker;6135301]Funny my c20 got it two, a coil, plugs, and reman dizzy, and clean ed the wires behinf the cluster and alternator hook up for remote volt reading. Some day I like see the farm truck
Posted via Mobile Device[/QUO
Just let me know when you plan to hit the Pavilions or some other car show and I will spin over. I put 50 miles on it in downtown Phoenix yesterday. 108 degrees and no A/C. I am not scared.
endlessearth is offline
Old 06-21-2013, 06:45 PM   #7954
19666Trucker
Old grumpy is my daily he been working me over wife say he going to be new lol
Old 06-22-2013, 12:42 AM   #7955
Trsmotrhed
Trsmotrhed's Avatar
Installed my bed sides and hooked up my fuel tank door.
Worked over the stock Tahoe fuel setup.
Fuel door came out great
63 SWB C10
Old 06-22-2013, 02:10 PM   #7956
TJ's Chevy
TJ's Chevy's Avatar
Started mine today.
Vacuum leak fixed.
Water heating system not leaking.
Intake and exhaust header sealed properly.
Ticked of the neighbors....accidentally....I mean come on it's running straight pipes! HMM. Must be to loud or something....Wish I could drive it that way.
And last but not least, it runs like a champ! Its gettin to be a scary 6 cylinder though!
TJ's Chevy is offline
Old 06-22-2013, 08:27 PM   #7957
Andice
Andice's Avatar
Put the bed on mine today. And drove it for the first time with its 305 V6 and 4spd trans.
Andice is offline
Old 06-22-2013, 08:34 PM   #7958
jayoldschool
Moderator
How did you see out the window? lol
Looks great!
jayoldschool is online now
Old 06-22-2013, 10:29 PM   #7959
62 Barnfind
62 Barnfind's Avatar
Truck looks great and love the color! Driving it makes it worth all the time and effort.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline
Old 06-22-2013, 10:30 PM   #7960
62 Barnfind
Installed new wheels and tires!
John Z
62 Barnfind
Old 06-23-2013, 12:50 PM   #7961
towersddg9
towersddg9's Avatar
Well rolled it out today, been busy with the kiddos gokart racen, I am officially registered for the Oct Goodguys event
towersddg9 is offline
Old 06-23-2013, 01:00 PM   #7962
19666Trucker
Finishing up the PO wonderful wire job twisted patches and wire nuts. I know it's a long bed but but nit a house
Old 06-23-2013, 05:34 PM   #7963
Lugnutz65
Lugnutz65's Avatar
I test fit my 88 Camaro world class T5 on the bell. I already swapped in a tail housing from an S10 to move the shifter forward. Looks like I can use my e-brake cross member as a tranny support. It's in the perfect location. I'll remove the center e-brake mechanism and remove the frame rivets and bolt it on instead.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 06-23-2013, 06:15 PM   #7964
jayoldschool
Moderator
Finished the refurb on my driveshaft. New U joints, new center bearing.
Old 06-23-2013, 08:36 PM   #7965
jbgroby
jbgroby's Avatar
Worked on getting the antenna installed. The new after market unit I got from LMC (same as others I would suspect) may all have this problem.
The existing hole from the factory (you can tell if it OEM factory because the hole has a slight notch) is designed for a slightly different antenna base. The one from the kit will need to have the rubber bushing/gasket glue in place to hold it while you tighten down. Also the lower mast brace is too short, I had to make a new one from a piece of flat bar aluminum.
Picture 1 shows the original and the new heavier long brace. I was able to use the supplied speed washers and wrap-around.
Picture 2 shows the hole you have to drill to mount the brace through.
Picture 3 shows the new brace mounted.
Picture 4 shows the assembly braced at bottom.
Pictures 5 shows the size of the kit supplied vs. home made brace.
jbgroby is offline
Old 06-23-2013, 08:39 PM   #7966
jbgroby
jbgroby's Avatar
Con't
This is the new antenna, although leaning inward, there is nothing I can do about it right now until I find a different mount.
Also you will have to use a step drill to enlarge the factory antenna cable holes because of the heavier insulation.
All in all about an hours work.
jbgroby is offline
Old 06-23-2013, 08:41 PM   #7967
jbgroby
jbgroby's Avatar
When I finished up with the antenna, I mounted the spotlight. I replace the switch wire as well. Added the mirror as well
jbgroby is offline
Old 06-23-2013, 08:43 PM   #7968
jbgroby
jbgroby's Avatar
Sat in truck with hood fully close and got this picture,
View to a Kill
jbgroby is offline
Old 06-24-2013, 01:04 AM   #7969
Trsmotrhed
Trsmotrhed's Avatar
Installed a overflow reservoir for my coolant. Sorry for the crappy pic.
63 SWB C10
Old 06-24-2013, 01:07 AM   #7970
88Lt1wagon
Left my ignition switch on last week or the week before, so I tried to jump it today with the wagon so I could take the dog to the river. Ended up having to pull the wagon's battery to put in the C10 to get it started, then swapping the dead battery back in while it was running so the alternator could charge it. I hadn't made the ignition mistake in a long time.
-Jason
'66 C10 LWB 2 BBL 283 w/ T-5
'90 V1500 Suburban TBI 350 w/ 700R4
88Lt1wagon is offline
Old 06-24-2013, 10:32 PM   #7971
19666Trucker
Posted via Mobile Devicegot my west coast mirrors on yesterday's the alternator wants to charge to 18 volts and load down the engine got my tach in and bunch of other little stuff. Still a vacuum leak I am chasing transmission modulator next.
Old 06-24-2013, 10:39 PM   #7972
1964Chevy
1964Chevy's Avatar
Took out the crappy electric fan, put the flex back in with the broken taped together shroud.
Drove it all over North Texas.
Cleaned it some more and took some pictures of it.
If your strength is small, don't carry heavy burdens. If your words are worthless, don't give advice. Chinese Proverb
Last edited by 1964Chevy; 06-24-2013 at 10:43 PM. Reason: The pictures did not stick
1964Chevy is offline
Old 06-24-2013, 11:45 PM   #7973
markeb01
Senior Enthusiast
markeb01's Avatar
Received my exhaust cutouts this afternoon and set up an appointment for 08:00 tomorrow morning to have them installed!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 06-25-2013, 01:11 AM   #7974
lasher78
lasher78's Avatar
i walked by mine to go to work thinking "man i got to get some rear tires so i can get this old girl to my buddies house to start work" then said yet another day....
live like you are dying
lasher78 is offline
Old 06-25-2013, 04:42 AM   #7975
Psycho75
Psycho75's Avatar
Found out that my driveline I had done had a yolk with the weep-hole in it. it leaked about a quart of the trans fluid on my driveway. So today I JB welded the weep-hole shut as the yolk doesn't move like on a one-piece driveshaft truck.
"You can have it Fast, Safe or Cheap. Pick any two"
"If you're gonna be dumb, you better be tough"
1965 C10: http://67-72chevytrucks.com/vboard/s...=1#post6114617
1971 Baja: http://www.thesamba.com/vw/forum/viewtopic.php?t=459552
Psycho75 is offline
Closed Thread
