VA72C10
![]() Join Date: Mar 2008
Need power steering low pressure fitting
Need the fitting that screws into the box and has a short section of metal tubing that you put the power steering hose onto. I have a new high pressure line but haven't been able to locate my low pressure fitting and the ones I've sen in the parts stores haven't looked correct.
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
![]() Join Date: Sep 2005
Re: Need power steering low pressure fitting
I bought my return hose from advance auto parts and it had that fitting in the hose witha pressure clamp just srew in and go ill see if i can find the number for u
VA72C10
Thanks a ton! I had them look it up in the store and they couldn't find anything. I will call and see if they stock either of those part numbers or order it.
Np i broke mine i thought i was screwed till i found thoses
VA72C10
looking at that again and it comes straight up. That would be into my inner fender...will see if I can bend it but does anyone else have an option they've used that looks more like the high pressure hose that lays flat against the frame with a tight bend coming out of the ps gearbox? Thanks
VA72C10
See this drawing on LMC...I can order one of these but would rather pick one up local because I need it within the next week.
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=128
Jonathon, Inline tube carries the correct one. I do not think I have in stock but I will check for you tomorrow
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
#10 | |
VA72C10
I'd be interested in one too...any pictures to verify? Thanks!
Sorry, did not have any in stock
VA72C10
Thanks for checking. Do you know the correct part number by chance?
Cts7101
#15 |
VA72C10
Thank you very much! Have a great weekend!
#16 |
I need one too!
LMC charges too much for shipping when you just buy a cheap part or two, it's not worth it. Last time I paid almost 11 dollars shipping for a 5 dollar part. Posted via Mobile Device |
