Old 06-23-2013, 12:18 PM   #1
chevynova22602
chevynova22602's Avatar
automatic steering column
Has anyone done a three on the tree swap to automatic if so what all will work and how far in year model can I go I'm working on a 1969 i need linkage column and everything thanks
chevynova22602 is offline   Reply With Quote
Old 06-23-2013, 03:26 PM   #2
CastIron
CastIron's Avatar
Re: automatic steering column
I've been thinking about doing this to my '69 gmc for years. In fact, I have a parts truck with just about everything to do it. (it just hasn't been a priority)
The easiest way is to find a complete truck (67-72) and swap parts. You will need to remove the 3 spd bellhousing crossmember (riveted in place) and use one that mounts on the transmission. And swap steering columns and possibly driveshafts. If you use a TH350 trans (and I think 700r4), you will have to hook up a cable to the throttle. The TH400 trans uses an electric kickdown you'd have to run wiring for.
I think just about any year trans will work, but the column, linkage, and crossmember will need to be 67-72.
My information may not be 100% accurate. Hopefully somebody else can tell you anything I've missed.
CastIron is offline   Reply With Quote
Old 06-23-2013, 05:52 PM   #3
chevynova22602
Thanks castiron that is some good info and yeah those rivets are a pain lol
Old 06-23-2013, 06:07 PM   #4
c10monkey
c10monkey's Avatar
I got a good used colum off of ebay for 100 bucks. I had to get the intermediate shaft as well as mine was a one piece column. Then bought the aftermarket shift linkage kit from LMC...
Works great... only thing I found is that the needle doesn't line up on "D" all the way...
1971 Chevrolet C10 Inflation Fighter
1994 C3500 Crew Cab Dually 454
c10monkey is offline   Reply With Quote
Old 06-23-2013, 07:13 PM   #5
chevynova22602
Cool that's what I was hoping for thanks c10monkey
Old 06-23-2013, 07:30 PM   #6
ufbugman
just finished mind, swapped out the column and got some linkage from LMC .
ufbugman is offline   Reply With Quote
