Re: Motor Mounts Problems - Putting in a 78 350
try slacking off on all of the bolts esp where the perches mount to the frame and crossmember. that should give you some wiggle room. thake the weight off the mounts so that you can just move them
ron |
#2 | |
Also, do I need the front motor mount if the two sides are good? Posted via Mobile Device
Current Vehicles: '62 C10 - 350 (current project), '03 Tahoe (C Series) Some Past Projects: '69 Nova - 350 , '70 1/2 Camaro Z28 - LT1 350, '73 K20 Full-time 4x4 - 400 SB, '77 1/2 Camaro Z28 - 350, '84 Camaro Z28 - 305, '68 Buick - 430 BB |
by frt motor mount are you talking frt timing cover area?. if you are installing a 350/350, you require the 2 side mounts on the side of the eng block and the one under the rear of the trans.
those perches shouldn't be welded in. it removes the possibility of being able to move them like I suggested, but is easier to install if it works ron |
#4 | |
![]() Join Date: Mar 2012
I would suggest cut the welds and get the perch mounts bolted in way they should be, leave the bolts loose until motor installed and then tighten everything up. had to do that with mine when put the small block in.
60-66 Nut
You do not need the front motor mount in addition to the side motor mounts. It is just either the front or side mounts. However with a auto trans you must have side motor mounts. The motor mount brackets you have on the sides don't sound to be original. Just eliminate the front mount and see if everything bolts up. Having the front mount is actually working against you. There is no physical difference between a '68 small block and a '78 small block.
