Re: 700r4
Hi folks: I was just about talk about 700r4.
I just install a 305 engine, Quadrajet carb, edelbrock intake,3.42 rearend and 700r4. And I only have about 11 miles/gallon. Forgot to say I don't have the lock up. |
Re: 700r4
The lock-up needs to function!! The Planetary gear sets oil through the lock-up circuit while in 4th gear. A long hot trip in 4th can destroy them.
#3 | |
Re: 700r4
No disrespect meant but doesn't the cooler circuit come off of the converter clutch valve? For all gear ranges? not just fourth? I don't remember if the cooler circuit is restricted during lock up or not. I'll agree that overdrive transmissions need a lockup converter (in OD) to reduce the chance of overheating the fluid. This is especially true in heavier vehicles.
#4 | |
Re: 700r4
The Lube/cooler gets its oil from the pressure regulator valve......It provides plenty of fluid in all cases except 4th when pressure is reduced. If you run in 4th with the converter un-locked, It effectively "double restricts" Lube/Cooler flow. This is the reason if you run a Non lock-up converter, A aftermarket Lube Valve is required to correct flow. TransGo 7-CCV for example. |
