Old 06-24-2013, 08:34 PM   #1
Coach529
Coach529's Avatar
216, 235, 261 distributer- Conversion or HEI
Still on points in Henry and want to update.
Pertronix Kit or a HEI distributer?
Thoughts or advice??
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 06-25-2013, 12:16 AM   #2
OrrieG
OrrieG's Avatar
Re: 216, 235, 261 distributer- Conversion or HEI
Go over to Stovebolts.com, there is a tech article on converting a later model 6 hei, just a little grinding on the shaft.
Old 06-25-2013, 09:05 AM   #3
Coach529
Coach529's Avatar
http://www.stovebolt.com/techtips/hei_conversion.htm
1949 Chevy 3600
Old 06-25-2013, 09:50 AM   #4
Yewhi
I've heard good and bad about pertronix, the bad mostly being failures. That said, I've had three over the years and am currently running them in my bronco and '55 3100 and have never had an issue. Basically a 20 minute install and aside from an extra wire it still maintains a stock appearance.
Yewhi is offline   Reply With Quote
Old 06-25-2013, 01:14 PM   #5
_Ogre
_Ogre's Avatar
both will get rid of the points, pertronics will look stock, hei is a little bulky looking imo.
i would base your preference on price and work involved, because i think their value is equal
when your looking at pertronix you don't need the new and improved version, ignitor II or the original ignitor work fine.
my son has had pertronix ignitor in his 68 elco for 14 yrs with no prolems
shop air compressor timer
Old 06-25-2013, 02:01 PM   #6
Coach529
Coach529's Avatar
Thanks guys!!
1949 Chevy 3600
Old 06-25-2013, 02:02 PM   #7
NEWFISHER
NEWFISHER's Avatar
I have had success with both in multiple projects. The last 2 have gotten HEI. The 55 wagon 235 used Tom Langdon's mini HEI and the Burb has a large bulky conventional HEI with 10mm wires. I live in the rainy NW and notice a difference in wet weather cold starts and overall run ability with a bulletproof ignition system. Drier or hotter climates may not notice a difference. Langdon's mini looks cool as it replicates the stock look, but you pay a little more for the looks. An aftermarket one is a little bulkier but less expensive.
NEWFISHER is offline   Reply With Quote
Old 06-25-2013, 04:14 PM   #8
HUSSEY
HUSSEY's Avatar
New guy here so I'm not sure if it's Kosher or not to post links to other forums but I did a write-up on the HAMB and ChevyTalk on the exact same topic a little while ago:
http://www.jalopyjournal.com/forum/s...&highlight=hei
http://www.chevytalk.org/fusionbb/sh.../fromsearch/1/
Here's a PDF that may be easier to print out:
https://docs.google.com/open?id=0B29...RnVsOXQ4V000UQ
One thing that came up after the conversion was the material of the distributor gear, either forged or cast steel. You need to make sure it matches the camshaft or you may have issues, I'm told.
HUSSEY is offline   Reply With Quote
Old 06-25-2013, 05:09 PM   #9
Coach529
Coach529's Avatar
This is a great post. Thanks!!
1949 Chevy 3600
