front brake conversion ?s
Im trying to find info about which years and models that will change out with my 68 gmc. I want to put a 6 lug disc set-up on it. I dont have the money to buy new stuff (the good stuff) so im going from this truck to that truck getting parts. I want to keep my 6 lug set-up. Any help would be very appreciated.
Re: front brake conversion ?s
Welcome to the Board!
Have a look at this thread for factory 6 lug disc setups: http://67-72chevytrucks.com/vboard/s...d.php?t=578979 But be careful about your wheels - if you've got the stock drum steelies you may need to replace them to work with the disc setups: http://67-72chevytrucks.com/vboard/s...d.php?t=580148
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
welcome to the forum
I have 2001 gmc wheels on it right now. Just got off the phone with summit. Just have more important things to put a 1000$ on right now instead of breaks on my truck. I'll check them out and thanks
Disc brakes are a great addition to any old car or truck. You can have all the "go" you want, but if it won't stop-you are in trouble. You could get a 5-lug setup from a 73-87 easily and cheap. Convert the rear later.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
Theres a pullaparts here and they have a 82-87 silverado so I will look into getting it. Does anyone know if the cross member is rivoted in or bolted? Might go ahead and get the rearend also and can I use the booster pump and master cylinder off of that truck? I want to get differ wheels anyway so I might as well go ahead and change to 5 lug.
TNT-MOTORSPORTS
Crossmember is bolted in , if you are getting booster and master get all the lines too . They will fit with some tweaking.
