Old 06-25-2013, 09:38 PM   #1
77chevyinline6
77chevyinline6's Avatar
Grinding noise in bellhousing ):
in my bellhousing of my saginaw 3speed when i let the clutch out it makes this grinding/rubbing noise/ the truck will jerk if you try to move it. i have the transmission yet just not the bellhousing because those bolts are soo tight and hard to get to but i will get that off tmw im just curious of whats going on I MISS MY TRUCK!
77 c10 (went from a inline 6 to 350) (converted to 3 speed in the floor)
350: mild cam, holley 600cfm 4bbl, summit stage 1 intake, accel billet distributer, flowtech headers, 2 1/4" exhaust with glasspacks, powermaster 160a alternator.
77chevyinline6 is offline   Reply With Quote
Old 06-25-2013, 09:57 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Grinding noise in bellhousing ):
Possible your clutch is just that worn that the rivets are grinding the flywheel.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 06-25-2013, 11:05 PM   #3
77chevyinline6
sorry but i forgot to add i just put a clutch in when i did the engine swap
Old 06-26-2013, 02:59 AM   #4
INSIDIOUS '86
Did you do a new pilot bushing as well? What about the pressure plate? What all is new And used underneath?
Old 06-26-2013, 09:45 AM   #5
geezer#99
geezer#99's Avatar
Did you put your disc in backwards?
geezer#99 is online now   Reply With Quote
Old 06-26-2013, 02:34 PM   #6
77chevyinline6
i did not put in a new pilot bushing but my clutch is installed correctly ive been driving the truck everyday until now
Old 06-26-2013, 02:38 PM   #7
INSIDIOUS '86
Could possibly be clutch chatter if the pilot is worn. If you replace it find an oilite type bushing
Old 06-26-2013, 02:42 PM   #8
77chevyinline6
i also forgot to add with the clutch out at idle you can look at the clutch fork and it vibrates very bad and so does the clutch pedal
Old 06-26-2013, 06:49 PM   #9
mrolds88
Here's a couple of thoughts. First about the pilot bushing. You can buy an actual bearing for this application. GM used them in the early diesel trucks. Second, with your noise problem. Two thoughts, first is your throwout bearing may have crapped out. Second would be that some of the clutch cover bolts may be coming loose.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 06-26-2013, 07:32 PM   #10
77chevyinline6
the throwout bearing seemed fine but when i took the transmision out the throwout bearing just kind of fell out..
Old 06-26-2013, 08:24 PM   #11
INSIDIOUS '86
The throw out bearing should stay on the clutch fork unless it pulled out when you pulled the trans. You have the fork clips in the inside if the groove of the throw out bearing?
Old 06-26-2013, 08:38 PM   #12
INSIDIOUS '86
Wouldn't suggest a bearing. Those are known to fall apart and chew up the input shaft and the input bearing gets beat as well. A good bushing has done the job since the early days.
Old 06-27-2013, 02:16 PM   #13
77chevyinline6
i had a "mechanic" install the the throwout bearing i really dont know how he had it
Old 06-27-2013, 04:18 PM   #14
INSIDIOUS '86
Ok well take it all apart and we can guide you in getting her done and back on the road. Worst we can do is fix it right?
Old 06-27-2013, 05:01 PM   #15
mrolds88
I agree with your thoughts on a bushing. I hadn't heard of the bearings giving problems though. Anyway lets get this truck fixed!!!!
93 K2500 xcab 6.5TD
Old 06-27-2013, 10:53 PM   #16
77chevyinline6
well guys a bit of and update but first of all i wanted to say thanks, but i got the bellhousing off and there was metal shavings in it! it was getting dark so i quit for the night but i will be back at it soon!
Old 06-28-2013, 12:14 AM   #17
INSIDIOUS '86
Well not a good start but let's hope it's nothing Superbad.
Old 06-30-2013, 01:18 PM   #18
mrolds88
Any updates???
93 K2500 xcab 6.5TD
Old 07-14-2013, 11:40 PM   #19
77chevyinline6
well guys, i started the truck without the traqnsmission hooked up and it sounded beautiful, took the pan off the transmission and found chunks of metal and steel balls. lol. good thing i found 2 700r4s for 100$ sorry it took me so long to update
Old 07-14-2013, 11:42 PM   #20
INSIDIOUS '86
So an input bearing or throwout bearing failure I presume?
Old 07-14-2013, 11:59 PM   #21
77chevyinline6
throwout bearing was fine, so i guess it was the input. i dont know much about transmissions this was my first truck and my first engine swap/rebuild and so on, but heres the pieces we found
Old 07-15-2013, 12:33 AM   #22
INSIDIOUS '86
Yup internal bearing. Saginaw trans right? Those aren't to hard to find
Old 07-15-2013, 12:38 AM   #23
77chevyinline6
yeah, its a saginaw. this is the 2nd one that has been destroyed in my truck. Having a heavy foot doesnt help though
Old 07-15-2013, 01:00 AM   #24
MalibuSSwagon
Yup late saginaws are pretty weak. Time to upgrade.
MalibuSSwagon is offline   Reply With Quote
Old 07-15-2013, 01:02 AM   #25
77chevyinline6
yeah, it was fine when i had my 250l6 in there and now with a mildly built 350 it didnt even last 2 weeks
