Old 06-25-2013, 03:15 PM   #1
MrMilks
MrMilks's Avatar
Dash Problem
So I got a new gauge cluster and as I took my old cluster out I broke some of the screw holes in the dash. Any ideas how to fix this?
MrMilks is offline   Reply With Quote
Old 06-25-2013, 05:05 PM   #2
johnnyclack
Location: On the banks of the Clackamas River, Eagle CreeK Oregon
Re: Dash Problem
Use this stuff by the case at work, (public Transit) it holds up well over the years
http://www.devcon.com/products/produ...m?familyID=175
johnnyclack is offline   Reply With Quote
Old 06-25-2013, 05:30 PM   #3
79Betty
79Betty's Avatar
Re: Dash Problem
We use 4 minute epoxy at jet. Same thing though
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 06-26-2013, 09:38 AM   #4
MrMilks
MrMilks's Avatar
Re: Dash Problem
What exactly do I do with the epoxy?
Old 06-26-2013, 10:00 AM   #5
johnnyclack
Re: Dash Problem
(this is just one way, there are others)
Repair the broken pieces, filling in the screw holes as you go. Return the next day & carefully drill undersize holes(shallow depth just to help the screws get started), if the originals are not self tapping screws then pick up some (same size / length) at your local parts store. Carefully install them, remember it’s only holding minimum torque.
Tip: By waiting until the next day for the epoxy to cure, the screws should remain removable....
Old 06-26-2013, 10:09 AM   #6
MrMilks
MrMilks's Avatar
Re: Dash Problem
Okay thanks man! This is awesome help. My new cluster will finally stop feelin like a red headed step child laying around the shop.
Old 06-26-2013, 10:14 AM   #7
johnnyclack
Re: Dash Problem
You may have to layer up the epoxy to get the hole deth you (might) need
