Old 06-25-2013, 09:36 AM   #26
bumwine
bumwine's Avatar
Re: Suspension sag
Thanks! When I fix this front end issue I decided I'm going to rebuild the front end as well while I'm under there. Was gonna use the ECE rebuild kit
bumwine is offline   Reply With Quote
Old 06-25-2013, 12:07 PM   #27
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Suspension sag
Anything from ECE will work fine.
They have great parts,... and even better people working there.
Keith
Convert to disc brakes.
Old 06-26-2013, 12:37 AM   #28
Square_78
Square_78's Avatar
Re: Suspension sag
235/75r15 tire is way t big bit remember when you install a smaller tire, the truck will also get lower to the ground. I say take out the bumpstop and mount as Lolife99 said earlier. You should prob crawl under the truck and have a look around and measure a few things and find out why only the pass side rubs. Could just be the big stock size tires but who knows. I run 215/70r15 on the front of both my trucks.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 06-26-2013, 10:49 AM   #29
bumwine
bumwine's Avatar
Re: Suspension sag
Well I hope to get new tires here in a week or two. Then I'm going to remove the bump stops and go from there. When I tear off the front clip for the motor swap I've decided to go ahead and rebuild the front suspension as well as put in new drop springs just to feel better
