Old 06-26-2013, 08:23 AM   #1
Dnrice
Oil sensor whole on block is plugged
Was going to put line from sensor to hole on block. However, it looks like po blocked hole with something. He might have even welded it but it is kinda hard to tell. What do think I should do? Scrap the idea of having a working oil gauge? Drill a hole in the screw?
Dnrice is offline   Reply With Quote
Old 06-26-2013, 08:38 AM   #2
DT1
DT1's Avatar
Re: Oil sensor whole on block is plugged
I don't know why someone would weld it in. I believe it's a 1/8" pipe thread.
DT1 is offline   Reply With Quote
Old 06-26-2013, 08:40 AM   #3
Rufton
Maybe you could take a closeup photo and better see what's going on.
Rufton is offline   Reply With Quote
Old 06-26-2013, 09:24 AM   #4
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I would clean it really well itis probably a plug with an allen head or something like that. X2 on pics
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 06-26-2013, 10:31 AM   #5
BurnoutNova
BurnoutNova's Avatar
It should be 1/8" npt thread. There is another oil pressure port if that one is permanently blocked, it is right above the oil filter and it is 1/4" npt threads.
BurnoutNova is offline   Reply With Quote
Old 06-26-2013, 12:02 PM   #6
Dnrice
Here is pic:
Old 06-26-2013, 12:04 PM   #7
Dnrice
I don't know, maybe this is not the port?
Old 06-26-2013, 12:06 PM   #8
GRX
GRX's Avatar
What engine are we talking here?
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 06-26-2013, 12:07 PM   #9
Dnrice
350 double hump
Old 06-26-2013, 12:13 PM   #10
BurnoutNova
That is the port... it looks like they either broke something off in the hole, or rammed something in there to block it off. I wouldn't mess with it and just use the other port.
Old 06-26-2013, 12:14 PM   #11
Dnrice
Where is the other port? And I was kinda thinking the same thing. I could see not getting the port sealed since it looks like it is stripped.
Old 06-26-2013, 12:19 PM   #12
RRR18
RRR18's Avatar
That pic looks like a well rounded off plug to me. Friend of mine had same sort of thing on a Monte Carlo years ago. We twisted his out when we did intake swap. You might be able to twist it out if you can get ahold of it.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 06-26-2013, 12:31 PM   #13
GRX
GRX's Avatar
Ports are by the distributor, over top the oil filter, and on top front of the block by timing cover.
Old 06-26-2013, 12:59 PM   #14
BurnoutNova
It is right above the oil filter.
Old 06-26-2013, 01:16 PM   #15
GRX
GRX's Avatar
It is right above the oil filter. [IMG]http://www.transamws6.com/pics/transam/piston02.jpg
#5 piston looks great! Someone drop a screw down the carb?
Old 06-26-2013, 01:54 PM   #16
BurnoutNova
Looks like it, lol. I don't know the history of this one I googled a pic to show the oil pressure port.
Old 06-26-2013, 05:40 PM   #17
Dnrice
OK, found maybe port by oil filter. There is nothing blocking it and there is oil around the area. I stuck the nylon down the hole and it was like a bottomless pit. Probably went in about a foot and a half. Next to it is a bigger hole. Do you think this is it? Why would it be open? This also might explain why I leak oil in my garage.
Old 06-26-2013, 06:13 PM   #18
GRX
GRX's Avatar
Look at the image BurnoutNova posted. The oil galley plug is seen right above the oil filter. A foot and a half deep sounds excessive. That passage should only go to the vertical galley just above the #5 main cap that goes up to the plug by the distributor. Here is an image from the web. It also shows the often forgotten hidden press-in cup plug under the cap which diverts oil to the filter.
