06-26-2013, 09:10 AM | #1 |
Is it possible to install bed with no wood in it
Is it possible to install bed with no wood in it? just the frame?
and if so is there anything special I would need to do Thanks in advance! Eric |
06-26-2013, 09:57 AM | #2 | |
Re: Is it possible to install bed with no wood in it
Current Vehicles: '62 C10 - 350 (current project), '03 Tahoe (C Series) Some Past Projects: '69 Nova - 350 , '70 1/2 Camaro Z28 - LT1 350, '73 K20 Full-time 4x4 - 400 SB, '77 1/2 Camaro Z28 - 350, '84 Camaro Z28 - 305, '68 Buick - 430 BB |
06-26-2013, 11:26 AM | #3 |
Wouldn't you need spacers? Doesn't the bed sit on the wood with the wood between the bed and the frame, so 3/4" spacers would be needed (I would think).......
06-26-2013, 11:42 AM | #4 | |
06-26-2013, 11:55 AM | #5 |
I used some big hex nuts that were about 1/2" for spacers. I also used some rubber strap material as a gasket to prevent noise.
06-26-2013, 06:42 PM | #6 |
I seen a trick little set up a couple days ago on a truck in my area. He had these cool looking alluminum rails that were 3/4 inch taller than the stock cross sills, so the bed would sit right.
06-26-2013, 07:04 PM | #7 | |
btw..i do not have a wood floor in my bed as well. Last edited by ChefCy; 06-26-2013 at 07:04 PM. Reason: added |
06-26-2013, 07:15 PM | #8 |
Unfortunately, those are all the pics I was able to get aside from the truck itself. It only had a pipe notch, so nothing crazy. He basically said he just replaced all of the original cross beams with the alluminum ones that he made. Very simple, but worked perfect.
06-26-2013, 07:38 PM | #9 |
thats a cool idea and a nice truck
06-26-2013, 09:02 PM | #10 | |
06-26-2013, 09:10 PM | #11 |
Do you guys have any pics of how you did your spacers? I need to do this to my bed.
- Ian 1966 C10 Longbed 350/350 |
06-26-2013, 09:39 PM | #12 |
Moderator
Spacers need to go up at the front corners of the bed, under the inner bedsides, on top of the frame. I have my bed off/wood out now, I can take pics tomorrow if needed (but it is pretty easy to understand if you look at your truck).
06-26-2013, 09:49 PM | #13 |
Ok thanks, And I guess I should have asked what is it that you used for spacers?
06-26-2013, 10:17 PM | #14 |
Moderator
06-27-2013, 12:45 AM | #15 |
No wood in the bed of my 65. I still have the boards running along the bed sides, which you can somewhat see below.
Posted via Mobile Device Posted via Mobile Device
Danny 64 C10 SWB fleet |
06-27-2013, 10:15 AM | #16 |
My truck bed is installed without wood ,and before everyone goes crazy cause they saw wood in there, That is jut a 4x8 cut to size that i laid on there for temporary use around the farm.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
06-27-2013, 10:52 AM | #17 |
Moderator
The two board's in gixxer's pic are exactly what you need.
06-27-2013, 10:57 AM | #18 |
C10 CLUB Y QUE!
let see some pic or the spacers
06-27-2013, 11:18 AM | #19 | |
It's Better With Nitro
I had some 0.75" thick aluminum bar stock laying around and cut that up for spacers. You can see a pair next to the forward gas tank tab mounts. I had that cross sill removed to work on the gas tank plumbing.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
06-27-2013, 01:40 PM | #20 |
63 big window lwb bagged and shaved |
