![]() Join Date: May 2010
ECE 4/6 Owners pulling the trigger. Have some Q's
So I'm ready to pull the trigger on the ECE 4/6 kit. I have read numerous threads about meausuring prior to have a baseline. Right now my bed is off and I'm doing other work on it in which it wont be back on for sometime.
Is this going to be a showstopper for me? I can measure the front to the front fenders, but not the rear. Any suggestions? Thoughts? Should I proceed in purchasing? I would think actually have the bed off would make this install easier. I just dont want to shoot myself in the foot, as I have saved for a long time to buy this kit and dont want to make a mistake. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: ECE 4/6 Owners pulling the trigger. Have some Q's
No.
Taking the bed off makes it ALOT easier. Buy the kit. ECE makes quality stuff. You will like the 4/6 drop. Posted via Mobile Device
Thanks lolife! Your help in 72blkbeauty's posting about the measurements was a superb idea.
That is what made me think of measuring. With that being said, I think I will call Stan up ![]() |
get the kit, you won' regret it. have the same setup on my rig and love it. wish i would have had the bed off my truck when i did mine, would have been way easier.
68 c20 build: http://67-72chevytrucks.com/vboard/s...d.php?t=358130 Club longbed ...cause girls like'em long!!!!! |
![]() Join Date: Apr 2012
ECE is a great company who will make sure you are happy. In another thread I talked about how my front end was too high, ECE sent me new springs with return shipping prepaid. Turned out they had sent big block springs on accident.
Btw, it was my first attempt at dropping a vehicle and its not as difficult as I thought it would be. Just be cautious when you remove the front springs. Good luck. Posted via Mobile Device |
I'm in the process of installing the 4/6 kit on my truck!
My project changed direction mid-build, switching from a LWB to a SWB stepside. Because the SWB uses different springs, I contacted them and they sent me different springs! Their customer service seems to be top notch.
Will 1970 CST10 SWB LQ4/4L80E 2004 Silverado (sold) 2007.5 Dodge Ram 2500 |
I just installed the same kit on mine last week with the addition of 1" blocks in the rear. Needless to say I like the stance a lot more. I plan to finish the front this weekend.
Are you running a c-notch on yours? |
The ECE kits are well made and ride good. Adding a link to the thread Sklptrljay was referencing above so you can see a little more what to expect on the finished product.
http://67-72chevytrucks.com/vboard/s...d.php?t=583751 |
Great kit. I did the 4.5/6 drop (spindles were 2.5) with ECE power disc brake conversion. The kit went on without any problem. Everything is well made. I had a few questions about the installation and so I called ECE and they talked me through it. Great customer service.
'67 2wd LWB 350/4speed. |
Buy the kit. make sure you paint the parts that are not painted before install. Rotors, calipers and master cylinder will rust in no time if you don't.
1970 Custom Original 400/400 Now ZZ454/4L80E/Edelbrock Pro-Flo 4/3:73 Eaton Posi PS PB and cold factory air Early Classic 4.5/6 Front 20X8.5 Riddler 4.75 inch bs Pirelli 255/40/20 Rear 20X10 Riddler 5.5 inch bs Toyo 295/40/40 Rear end is original wide 6 lug converted to 5 lug |
Well. I bit the bullet and just now ordered my 4/6 kit. Big thanks to Stan for taking the time with me. I feel that this kit will be outstanding based on others, and the fact that Stan mentioned they will work with me should my stance not be correct with springs etc...
Overall quite pleased and the kit isnt even here ![]() |
OK the kit was just delivered to my door a few moments ago. After taking everything apart, does ECE no longer stamp their name in the spindles? Mine are black and nothing to em. Was kinda hoping for their slick silver spindles with their name etched in em.
![]() Join Date: Dec 2012
72tutone,
I put mcguaghys 2.5" drop spindles on my sons truck they looked the exact same.....funny is that both companies are in Fresno CA probably the same foundery, but they worked great I have had no problems. I have Mcgaughys drop up front 3.5" and ECE Drop leafs and shakles out back 5.5" good luck take a few pictures before and after Scott
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
None of my ECE spindles have been silver.
They use to say Early Classic cast into them. They for awhile ECE was having production issues and was shipping Western Chassis spindles. I wouldn't worry about it. ECE wouldn't send you an inferior spindle.
#15 |
I certainly wouldnt think they would either, but I wanted to check to be sure. Also their shocks that came with my kit are the excel-g2 version. Mine are all black. I'm not sure if the other kyb's in the pic are different or not from their website. Or perhaps is because mine are a supposed "dropped" version?
I dont know. Again this is all of curiosity. I'm sure they are fine. <Edit> Just looked at the part number on the shock 344068. Looks like they vary from black or gray. |
#16 |
I think the shocks are the same as the drop is almost all spindle which doesnt change the travel. if you use a drop spring of like 2" or more you may need a shorter shock.
if i am wrong someone will chime in! and if i am than maybe i need different shocks!!!! ![]()
#17 |
First C10.
Yep they are McGaughys for sure. And I specified to ECE the 4/6 drop 2.5 spindle with 1.5" springs. According to McGaughy's site I must use 1 1/4" rotors. Does anyone know if the stock rotors are this thick on a 72? Check this link out from Jegs. Identical. http://www.jegs.com/i/McGaughys/654/...rentProductId= Last edited by 72tutone; 06-27-2013 at 12:24 PM. |
#18 |
Ya mine are black like yours in the picture. They fit well the only thing I had to get was the backing plates. i got them from CPP off ebay the cheapest like 50$ shipped.
I live like 1 hour from fresno and know a guy that knows a guy!! you know ??? that is why i have mcguaghy front and ECE rear. but both make great products. I havent had any issues with either places products.
#19 |
Junior Member
My guess is that ECE makes them for MCGaughys.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
#20 |
Actually I think Western makes them for both!!
#21 |
Junior Member
#22 |
Yeah i read that before but I think they are referring to the actual machined part that the bearings ride on and is pressed in the outer spindle part. but they are definitely the same product.
#23 |
![]() ![]() Join Date: Jan 2011
So, you aint done yet ?
#24 |
It's an old picture truck is done at least for the drop anyways. Check my avatar. This is with the bed off. Getting ready to relocate gas tank.
Posted via Mobile Device Posted via Mobile Device
