Electric fan wiring issue
In my '49 I am currently running a 2 speed older Taurus/Sable fan. I am also running a 21 circuit EZ Wiring harness throughout the truck also. The truck is outfitted with LED turn signals and tail lights.
There really isn't much pulling for power on the harness I believe (my uncle is doing the wiring on the truck). Everything is hooked up at the moment except the fan and it seems every time he tries to run the fan he blows a fuse. How did all of you guys running electric fans hook them up?
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
Re: Electric fan wiring issue
Some of the higher amperage fans run a relay.
I found this on a Taurus forum
Thanks. Yeah at the moment he has a relay in the loop. He said last night he tested it and when the relay is in the circuit (think that is the proper term) the fan does not work, however when he bypasses the relay the fan works fine.
Also thanks for the diagram, I will send that over to him.
#5 | |
I've experienced relay failure; the relay contact developed a white crust. Now I run redundant relays, redundant switches and redundant fuses. Occasionally, I verify both high current circuits are functioning; which reminds me I need to check em.
You probably know a relay can allow a low current circuit to trigger a separate high current fan circuit. I do have fan rated fuses in the high current circuits. |
#7 | |
I see I am not the only one that does that
The two speed ford fans really need a hefty relay. They cool great but pull high amps, and that can burn up a small relay quick. If it happens again try a heavier relay.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
#11 | |
I told him I wanted to look at it when I was home next week so I will have to see what it is.
#12 | |
Two completely independent circuits. Relays can run simultaneously or independently. Both circuits are automatic and live. One of those overkill kinda things.
