06-27-2013, 11:39 PM | #1 |
62 c10 v8 Engine Mounts
Can some one tell me what year v8 engine mounts will work in my 62? It has a:235 in it now.
06-27-2013, 11:56 PM | #2 |
60-66 Nut
Re: 62 c10 v8 Engine Mounts
You can use the '67-'72 truck small block motor mount brackets. They work fairly well, but may require a small (1/4") spacer on top of the frame. I would try them without first.
Here is a pic of them sitting in a '62 GMC frame at the correct center to center measurement.
06-28-2013, 12:06 AM | #3 |
Thanks for the help I will try them. For the motor are they the center bolt? for 67 and up.
06-28-2013, 12:42 AM | #4 |
60-66 Nut
The pickup motor mounts are the same from '63-'72 for the small blocks, and the 230,250 and 292 I6 engines. They are number 2882 motor mounts.
06-28-2013, 01:01 AM | #5 |
Thanks again for the info.
