Show me your hood props
The original hood hinge springs ('53 AD truck) sagged and made the hood a head knocker and the new ones are so strong they push the back of the hood up off the cowl. I need some hood prop ideas other than a broom handle.
Re: Show me your hood props
Have you gone through the correct process to align the hood? If not followed correctly the back of the hood will be lifted from the cowl.
I used an old broomstick when I didn't have the springs hooked up but the hood always lifted up in back and never seemed to fit right without the springs.
I've done the hood adjustment using my repro assembly manual and everything looks great untill I hook up the springs. The center of the hood lays lightly on the rubber seal but the ends are pushed up and flutter at hiway speeds.
Maybe adapt a pair of hatch back gas cylinders.
Elev8r Man
I am going to use a piece of clear polished anodized aluminum tubing to hold it up
1955.2 C4 Carry-all / Suburban ![]() 1958 Fleetside SWB ---> 58 Fleetside Build thread 1939 2 door sedan My F.B. project page. |
heres mine in the making
![]() . bagged and soon to be bodied 70 longbed http://67-72chevytrucks.com/vboard/s...d.php?t=564028 |
knock out the prop rod and it will be a decapitator
![]() why not fix the problem rather than booger it up?
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Had this problem with both my 55 Ponch and 55 GMC even with new springs. My solution was to set the hood to the position I like and measure the length of the springs then cut a piece of coat hanger wire slightly longer than this measurement, and bend hooks in the end. Now raise the hood slightly higher and slip each end over the spring. One will hold the hood up but, one on each spring is safer when working under there. You can still close the hood and not damage anything if you forget they are there, the ends will straighten out under tension. I use a small rare earth magnet to secure them out of sight under the hood when not in use. ............... Works for me
