'76 drop spindles on '72
hey guys, was wondering what was neccessary to swap in '76 drop spindles onto my 72 c10, other than upper ball joints and tie rod ends. any help would be much appreciated
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: '76 drop spindles on '72
That's it.
They both use 1-1/4" width rotors and calipers. Upper balljoint and outer tie rods. Done.
Interested in this,
Does one also need the center link, pitman arm, and idler arm from the '76?
![]() ![]() It ain't yours, if you didn't build it! |
#4 | |
You can just change the outer tie rods. 63-70 trucks, have completely different sized steering components,... so you would benefit from using the 73-87 steering when using 73-87 drop spindles.
Good info to know!
lolife is correct, I bought a wrecked '76 and put the Belltech drop spindles on my '72. No problem.
Haha awesome guys, thanks for the help. I'm trading one of my sets of truck rallys for a pair of belltech spindles
Posted via Mobile Device |
