Old 11-28-2003, 05:46 PM   #1
SEVEND2
SEVEND2's Avatar
Question Need help with Brake/turn lights
Ok, I got tail lights, but no Brake or Turn signal in the back
Any ideas
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction).
Progress on truck so far (follow link):
http://67-72chevytrucks.com/vboard/s...ad.php?t=51051
and stage 2
http://67-72chevytrucks.com/vboard/s...ad.php?t=58132
~ "Why couldn't you have just put the bunny back in the box?" ~
SEVEND2 is offline   Reply With Quote
Old 11-28-2003, 05:54 PM   #2
jef5150
Inline 69
jef5150's Avatar
fuse
jef5150 is offline   Reply With Quote
Old 11-28-2003, 06:02 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If not a fuse, probably turn signal switch.
Forget about the grounds...99.999% chance that is will NOT be the ground.
You have checked the bulbs already though, yes?
Old 11-28-2003, 06:42 PM   #4
SEVEND2
SEVEND2's Avatar
Ok, update........
Fuses are good, checked them ALL in the fuse block. I have Front Turn signals and on the inside.
The bubls i will check but could i loose both bulbs at the same time?
and stage 2
Old 11-28-2003, 06:47 PM   #5
67sss
67sss's Avatar
Got flashers in the back?
67sss is offline   Reply With Quote
Old 11-28-2003, 09:57 PM   #6
SEVEND2
SEVEND2's Avatar
Didnt check the flashers, But did not, they were not working either.
Took off lens covers and checked Bulbs.............What ya know, both blown
I guess when the Volt Reg went tout it Fried them
Lonhorn man, Jeff 5150, 67 sss
U guys
and stage 2
Old 11-28-2003, 11:24 PM   #7
Longhorn Man
Even though it seems stupid to double check them...I always do.
Proved the boss man wrong at the shop last week on this.
