#2501 | |
Re: What Did You Do With Your Truck Today ?
#2502 |
Elev8r Man
1955.2 C4 Carry-all / Suburban ![]() 1958 Fleetside SWB ---> 58 Fleetside Build thread 1939 2 door sedan My F.B. project page. |
#2503 |
![]() Join Date: May 2011
Hi, I have 2 sets of spears and 2 hood emblems. They're in fair shape~ actually I haven't paid much attention to them. Seems like they didn't line up with the holes on my truck. I'll look at them again tomorrow.
'72 Ford Bronco project(July 17 2021-?) https://67-72chevytrucks.com/vboard/...d.php?t=828015 59 Apache (sold 6-25-2021) 67 Ford Mustang (re-restored after Harvey) 1968 Jeep Cj5 (2-8-2020 to present) 1992 Jeep Yj (8-17-20 to present) (Jurassic build) www.Classiccarsandtools.com |
#2504 | |
![]() ![]() Join Date: Nov 2008
IF you put on the emblems may I suggest you get them re-chromed? The paint is too nice to install pecky, dull chrome. |
#2505 | |
Elev8r Man
![]() I didn't rechrome the fleetside emblems as I wanted a lil something to look original or least close to it. Posted via Mobile Device
#2506 |
I saw a member do this on his TF and it looked cool, so i moved my stock fuel filler neck to the rear of my AD fender today, all info and more pics in my build thread.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
#2507 |
I removed all the interior of my truck and am now preping everything for sand blasting.
Posted via Mobile Device |
#2508 |
That is a superb idea and well executed!
#2509 |
uh, pictures? we need a before and after
#2510 |
#2511 |
i found a fulton visor last week in the trash. smoothed out most of the big dents and reshaped some Bends. Now if you run your hand across it it reads i have bad hail in brail.
#2512 | |
Wow, I want to know what trash you where digging through, can you point me in that direction. Nice find, just run it through a English wheel and it will change what that brail says.
1948 Chevy 305, NV3500, 3.73 rear, sitting on a 95 s10 frame. Still in the works 2000 Chevy Extreme lowrider, 4.3, NV3500, 3.08 rear, upgraded/modded 2001 GMC Sonoma Zr2, 4.3, NV3500, Stock |
#2513 |
I found a bed for sale for my truck today as a reproduction but the side is pre drilled for only an extra $45
#2514 |
![]() Join Date: Aug 2011
Brought the Oil Pan, Valve Cover, and Spark plug side to the car wash and cleaned all the gunk off. Then I hit em with the wire wheel and degreased them. Used a roll of paper towels with some marine clean 5 to 1. Hit them with Prep and ready and them primed and painted. I bough the paint from the filling station as a chevy engine grey but am not liking it. Could someone recommend where to purchase the chevy engine grey blue so I can finish in that color?
Tanks Pat |
#2515 | |
#2516 |
I finished installing all my control arm bushings and ball joints. I shined everything up with knotted wire cups, wiped it all down with lacquer thinner. Then I hung everything up and hit it with 2 coats of primer then 2 coats of black. Hope it's dry enough in the morning that I can get the front end back together.
I didn’t paint the spindles because I’m planning to do 2 inch drop spindles in the future. I just want to be able to role this thing out so I can get to work on the engine and tranny clean up and repaint. This is only my second time painting. I'm using a Harbor Freight HVLP gun. I have to say that I have had good luck with this gun. Of course the undercarriage is a little less critical. But I have had no issues with runs or anything else. Good even coverage throughout.
av8tr33337 AKA Bartman ![]() Bartman's Ad-S10 Chassis Swap http://67-72chevytrucks.com/vboard/s...d.php?t=415418 My First Youtube Video http://www.youtube.com/watch?v=B6hSt...eature=channel More Pics of the 51 Project http://s668.photobucket.com/albums/v...hassis%20Swap/ 1951 3100 Pickup |
#2517 |
What brand paint are you using?
#2518 |
I just used Rustoleum Professional this time around. I did the frame itself with epoxy primr and some chassis black, but money is tight right now so I went a little cheaper.
#2519 |
I worked on the gas door while grandson helped his Mom prep the Mustang intake manifold for paint. Chevelle was just in the way... Got a fancy fire resistant/leather welding jacket while at the welding store for some wire.
#2520 |
Picked up the truck after having new king pins installed. Fitted a new brake pedal spring and stamped an engine number into the block. Weigh ticket and passenger mirror then hopefully licensed after my re inspection on Tuesday.
#2521 |
Photoshopped it into a "Toy Truck"
#2522 |
#2523 |
^ i like it !!!
#2524 |
#2525 |
Nothing to either truck but I put some smaller main jets in this.
Just Empty Every ![]() Last edited by mknittle; 07-06-2013 at 06:16 PM. |
