07-01-2013, 04:56 PM | #1 |
heater control module bolts....
Can someone tell me the size, or where I can buy whatever type of bolts attach the heater control module to the dash itself? Or what you used to mount yours.
Thank you
68' c10 stepper 5.3/4L60e Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578917 |
07-01-2013, 06:00 PM | #2 |
Watch out for your cornhole !
Re: heater control module bolts....
They are 1/4-20 thread bolts. Choose whatever style of bolt head that you prefer in that size. Typically, they are Phillips pan headed style.
Posted via Mobile Device |
07-01-2013, 06:02 PM | #3 |
Here's where you can buy them http://www.brotherstrucks.com/prodin...number=SET0116
07-01-2013, 06:20 PM | #4 |
Two bucks each plus shipping from Brothers.
I'm more of a 10 cents each down at Ace Hardware kind of guy. Posted via Mobile Device |
07-01-2013, 06:23 PM | #5 | |
07-01-2013, 06:34 PM | #6 | |
Also, to add to the discussion, I went out into my shop and dug out my box of heater controls. Some are 1/4-20 and a couple are like #10 sheetmetal screw threads. These are all basic heat (non air) control heads. I can't really say for sure if the ones that use screws have just been abused and had the threads cuts by just being forced or if they came that way. Posted via Mobile Device |
07-01-2013, 07:29 PM | #7 |
Mine has sheet metal screws. No clue if that is original or not.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
07-01-2013, 08:06 PM | #8 |
Ive tried 1/4-20 and they are too big, this is a replacement module from LMC so if that matters...lol
I may end up trying some sheet-metal screws. thanks
07-02-2013, 03:30 AM | #9 |
My used replacement controller had stripped threads.
I just used stainless machine screws (#10, I think) washers and stop/lock nuts. |
07-02-2013, 08:07 AM | #10 |
Old member
If you have the AC controller you need the bracket that fits to the bottom of the panel so the 1/4"x20 will screw into it. The panel it self doesn't come with it most of the time you have to take it off the old one and install it on the new one.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
