Old 11-26-2003, 09:48 PM   #1
Chevyguy111786
Axle swap done today
I did an axle swap today. put a 3/4 ton eaton full floater from (i think) a 67 or 68 chevy under a 70 1/2 ton truck. Got a question. The u-joint on the driveshaft is too small for the diff. what can i do? thanks
Chevyguy111786 is offline   Reply With Quote
Old 11-26-2003, 09:51 PM   #2
68c10owner
68c10owner's Avatar
you can get a adapter u joint. it has both sizes,one bigger, one smaller. my fried used one when he did pretty much the same swap on his 76 1/2 4x4.
Anthony
68c10owner is offline   Reply With Quote
Old 11-26-2003, 09:56 PM   #3
Chevyguy111786
any one know where i can pick one of these up?
Old 11-26-2003, 09:58 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
GET ONE AT ANY PART'S STORE THEY ARE ABOUT 26 BUCK'S HERE IN OREGON... ANY GOOD PART'S MAN WILL BE ABLE TO HELP YOU OUT..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-27-2003, 03:23 AM   #5
Chevyguy111786
THANKS LOADS! my truck should finally be up and runnin...puttin a flat bed on this weekend...woohoo!!
Old 11-28-2003, 06:45 PM   #6
Chevyguy111786
went to napa, they said they didn't have anything like that. i'm out of ideas. will the half ton yoke fit the one ton diff?
Old 11-28-2003, 06:53 PM   #7
fast14
fast14's Avatar
It won't fit. I've had this same problem at a lot of parts stores. Sometimes you just need to take the old u-joint in and the yoke if possible and pretty much draw them a picture. Most part stores will have these crossover u-joints but a lot of the people who work there don't want to look for them.
Just a little crazy
1970 chevy full size half ton, soon to be one ton running gear, 350 turbo, 205 case, 355c.i.
fast14 is offline   Reply With Quote
Old 11-28-2003, 07:03 PM   #8
Chevyguy111786
i took in the ujoint and all....they said they didn't have it. these guys are real good about spendin time and helpin me out. so i don't know. should i look for a specialty shop somewhere?
Old 11-28-2003, 07:06 PM   #9
fast14
fast14's Avatar
Have you tried another parts store?? I have bought u-joints like this at a lot of different stores. It's usually a big pain in the you know what though.
Just a little crazy
Old 11-28-2003, 08:20 PM   #10
Beast388
Suburbans RULE!
Beast388's Avatar
I purchased my conversion u-joint from Napa. I needed part #348 to connect my 1/2 ton driveshaft to the one ton 1350 size yoke. Napa carries all sorts of conversion u-joints, so I am surprised they said they couldn't help you.
The Eaton and Corporate 14 Bolt full floater are so similiar that I bet #348 would work for you. You can always return it if it doesn't fit.
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 11-29-2003, 12:01 AM   #11
Chevyguy111786
i'll try that in the morning...thanx again for the help
