61 master cylinder booster questions
All.
Was thinking of going to the local yard to get a booster and brackets etc.. I can get this from AutoZone for about $120.00 Can anyone tell me if they think this will bolt up to my firewall on the 61? See the pic below. Bracket is included
Glenn Korec Jamesville NY 64 C20 350ci Turbo 350 tranny 3.73 gear with air ride. 61 Apache10 (wife's truck) 327ci powerglide. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=570100 |
![]() Join Date: Oct 2006
Re: 61 master cylinder booster questions
In a nut shell no. Is your 60 an automatic or a stick ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
Its an automatic
Ok try this link
http://www.67-72chevytrucks.com/vboa...49#post3479149 The mounting holes on the 60-62 are difrent but this should do the trick for you.
Thanks for the link. Im not opposed to drilling some holes.
Glenn
are you going to swap out the drums?
already upgraded the front end from a 72 wd. Have 6 lug 1 1/4 rotors. New calipers, etc... Working on running new brake lines.
