Old 07-03-2013, 06:06 PM   #1
Chiva1971
Chiva1971's Avatar
Size Baby Moon Center caps for stock wheels 6 Lugs?
Hello. I hope you understand my question. What is the size of moon center caps in stock wheel 6 lugs? . 9" 1/8 or 10" 3/16?. Thank you very much . Juan M.
Chiva1971 is offline   Reply With Quote
Old 07-03-2013, 08:09 PM   #2
ole dollor
ole dollor's Avatar
Re: Size Baby Moon Center caps for stock wheels 6 Lugs?
my baby moons were 10" ,on stock 1970 c-10 wheel...could have been 10 3/16 " but i do remember 10 " any way
ole dollor is offline   Reply With Quote
Old 07-03-2013, 10:25 PM   #3
Square_78
Square_78's Avatar
Mine are 10.125" and they are a tight tight fit. You prob want one size bigger like 10.250" caps.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 07-03-2013, 10:42 PM   #4
Well,10 3/16" is 1/16" bigger than 10 1/8" (10.125"),so that's the one you want. There aren't but a couple sizes of hubcaps for US-made cars and 1/2t trucks. Chrysler broke the standard by using that little diameter and everyone else used the bigger. Some 4-lugs cars like Corvairs used a smaller size,too. Then 3/4ts all used the same third size that was larger.
Old 07-03-2013, 11:24 PM   #5
ole dollor
ole dollor's Avatar
they are a little hard to get on the first time and do fit tight, there is an art to installing them. do not hit the middle or down the sides, put them on so that only one wheel bump is showing and bump it down and to the side hitting just the outside lip when installing...seen a lot of bent ones...hope this is clear as mud....
Old 07-04-2013, 07:41 AM   #6
Hubscrub
Cruzin
Hubscrub's Avatar
^ yea and then it gets better after the first time, they won't fall off at least mine are 10 1/8
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 07-04-2013, 02:07 PM   #7
Chiva1971
Chiva1971's Avatar
Thank you very much to all of you for your comments. My idea is to put the moon center caps and ring trim 2 ". Now understand that the most convenient size is 10 "3/16.This picture is very nice.
Old 07-04-2013, 02:12 PM   #8
Chiva1971
Chiva1971's Avatar
In jest. By these sites we have a saying. Is not that my chevrolet loses oil, is marking its territory.
Old 07-04-2013, 07:37 PM   #9
ole dollor
ole dollor's Avatar
yep it marked its spot until i got the new power steering pump put on....lol
Old 07-04-2013, 09:16 PM   #10
You sure there wasn't a Ford parked there right before you? (You coulda said that and we'da believe it anyway)
Old 07-04-2013, 09:25 PM   #11
ole dollor
ole dollor's Avatar
i guess i should have, it does look bad for an old chevy to be doing that..lol
Old 07-05-2013, 03:11 PM   #12
Chiva1971
Chiva1971's Avatar
Then guys, we agree that it did at the presence of a Ford and this would be very good
