Old 06-29-2013, 03:51 PM   #1
BigRed76
BigRed76's Avatar
Anyone ever found these papers in their dash?
While replacing my dash pad, original by the way, this weekend I found the orange piece of paper under the dash pad, and found the white piece barely hanging on to the top of my gauge cluster. Even though they don't mean much to the truck I think they're awesome for the simple fact that these original pieces held on for 42 years...
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 06-29-2013, 04:45 PM   #2
SS Tim
SS Tim's Avatar
Re: Anyone ever found these papers in their dash?
Davidson was one of the manufacturers of dash pads and the 9/17/70 date would make me think it is from your 71.
The AC cluster tag with the part number is intersting in that it s a good example of the build sheet numbering system. Here is a clip from a 72 sheet showing the last four of the P/N but often the three letter quick identifier (QBB in this case) was used. Would love to have scans of both of those for my collection if you would.
SS Tim is offline   Reply With Quote
Old 06-29-2013, 05:26 PM   #3
vidman
vidman's Avatar
found this one under the original dash pad in my 72 cheyenne cab plus all the cab numbers
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 06-30-2013, 12:47 PM   #4
BigRed76
BigRed76's Avatar
Yes those came from my '71, the coolest part about finding them for me is it that I now know when my truck was actually built. The factory sticker on the driver's door is long gone that has the build date on it. Unfortunately I don't have any way to scan those onto the computer, just pictures.
Zach
Old 06-30-2013, 01:38 PM   #5
SS Tim
SS Tim's Avatar
Being vendor parts they only tell you that your truck was built after 9/18/70. Production lead time involved there. However when is kind of up in the air. Do you have the original block (with the build stamp) or a protect o plate for yor truck? If not I might be able to generalize it from your VIN if you want to PM it. No worries on a scanner if you had one great as never give up the opportunity for primary documentation.
Old 06-30-2013, 01:42 PM   #6
BigRed76
BigRed76's Avatar
Protect-o-plate is long gone but it does still have the original 307 in it. Where is the build date located on the block?
Zach
Old 06-30-2013, 02:17 PM   #7
SS Tim
SS Tim's Avatar
The block is stamped with the engine plant, build day/month along with the application suffix. This is found on the right front of the block at the head stamped into the deck face. It does not however give the year, for that you would need to fnd the casting date as well. Again the engine is a lead part also built off line and shipped to the plant for dressing and installation. So you will have the engine build date which will be much closer than a trim part but still not the actual vehicle build date.
http://67-72chevytrucks.com/vboard/s....php?p=5724293
http://67-72chevytrucks.com/vboard/s....php?p=6079875
Old 07-01-2013, 06:58 PM   #8
BigRed76
BigRed76's Avatar
Ok. I'll get those tonight and see what I come up with.
Zach
Old 07-01-2013, 09:41 PM   #9
BigRed76
BigRed76's Avatar
Well I'm about 99% sure my '71 still has the original engine. I was told when I bought it that it had the 307, which was not hard to believe due to the original appearance of it, and how it is grossly underpowered. But the numbers I got off the block are V0127THA off the front, and 3970020 off the rear. From what I found...
V0127THA:
V = Flint, MI
01 = January
27 = 27th day
THA = 1971, 307, 2 barrel, 200hp, m/t
3970020:
1969-73, 307, 115-200hp, 2 barrel, car/truck
So this would indicate that the truck was actually built sometime after January 27th, 1971. Only 4 months after the date under the dash pad
Zach
Old 07-01-2013, 10:16 PM   #10
SS Tim
SS Tim's Avatar
Very good now you are understanding. Depending on the plant you are probably looking at a 3 to 30 day range. Next test what is your rear axle build code if original?
If you find it the block casting date would be a nice too.
Old 07-01-2013, 11:59 PM   #11
BigRed76
BigRed76's Avatar
It is a fremont truck. The rear axle has the correct factory gear ratio, but I'm unsure of the originality. Where is the build code located?
Zach
Old 07-02-2013, 08:45 AM   #12
RANDY COX
RANDY COX's Avatar
yep found one in my 70 Burb when replacing dash pad..
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 07-04-2013, 03:23 PM   #13
BigRed76
BigRed76's Avatar
I had no luck finding the code stamped into the axle housing
Zach
