Closed Thread
Old 07-02-2013, 08:07 PM   #8051
TJ's Chevy
TJ's Chevy's Avatar
Re: What did you do to your truck today?
Drove my truck today and found my oil breather cap! It was on back of the motor stuck in between the header and manifold.....wonder how I didn't see it....
TJ's Chevy is offline
Old 07-02-2013, 08:20 PM   #8052
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Organized, sold extra parts and piled my 63 into a corner to work on next.
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline
Old 07-02-2013, 11:19 PM   #8053
jayoldschool
Moderator
Cleaned up a full set of cross sills for the bed. Paint next, then wood/strips install.
jayoldschool is online now
Old 07-03-2013, 09:33 PM   #8054
jayoldschool
Moderator
Wow, can't believe no one else did anything on their trucks today! lol
I got back to work, got the bolts out of one wheel tub. Had to break every one of them. Can't wait to put the bed back together.
Old 07-04-2013, 12:14 AM   #8055
CSGAS
optomistic ah-so
CSGAS's Avatar
Originally Posted by endlessearth View Post
Welcome to the forum. This is the right place to ask for sure. I have a 1964 C20 that I recently purchased too. Maybe you have a bad ground at the housings. I had some electric issues like you are having too. The thing that fixed my issues was fiddling with the rear light housings by screwing and unscrewing the screws that hold them in place until I got a good ground. I would only count as a shade tree mechanic if the tree had one leaf so I could be wrong. They might have turned on out of pity.
That was the one thing that did the most to help my taillights work again when I brought it home. I also cleaned the housing, polished the inside as best as I could and scuffed a spot clean to make sure there was no paint where one mounting screw on each side went.
Since then, I also had some problems re-occur, one being the brake lights not working. It could be the switch (at the brake pedal) or it could be the headlight switch. I know, "What does a headlight switch have to do with brake lights?" Trust me, they are connected.
Good luck! As for me I'm looking forward to replacing two more brake hoses and bleeding my brakes while I'm at a friend's for the 4th!
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline
Old 07-04-2013, 04:16 AM   #8056
kjc292
kjc292's Avatar
tryed tightening down my lifters due to a clacking sound that goes with the rpm of the engine. didnt do squat, thought it was a loose lifter... just bought a 67 292 to replace my 78 292. going to complete rebuild...well upgrade it. complete tear down. machined flat, lumped ports, bored.... believe its a lower end noise now... still has quick pick up in 1st... but hey its tow.
79' c20 std cab 292 3speed granny - daily driver.
77' c30 std cab 454 th400 4.10 - fathers truck then mine.
95' ford bronco 302 4speed overdrive.
2002 mustang auto v6 - girlfriends daily driver.
Debt just means that you had more fun than you're suppose to have
kjc292 is offline
Old 07-04-2013, 09:42 AM   #8057
LT1 Burb
LT1 Burb's Avatar
Well it turned hot here on the west coast and I ended up working 83 hours last week and its the 4th this week so have 40 -50 people coming over for a pig roast, to busy to get on the truck. This heat has made up my mind about air conditioning my shop though, that is my next project.
LT1 Burb is offline
Old 07-04-2013, 09:45 AM   #8058
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I picked this up to give up its drivetrain for the Burb .... Runs like a top, and likes to light up the tires !
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline
Old 07-04-2013, 11:52 AM   #8059
jayoldschool
Moderator
Great choice, LT1s are wonderful engines.
Old 07-04-2013, 12:47 PM   #8060
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
.... and I wont have the annoying "tick,tick,tick,tick" the LS's have
Actually, the would of preferred a 6.0, but I cannot complain.
I picked the entire car for $400, it runs like a top, and at 130k miles ... I should be good (engine anyway, GM trannys give it around this range)
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 07-04-2013, 05:06 PM   #8061
Trsmotrhed
Trsmotrhed's Avatar
Went to a local car show for the 4th. My truck was the only work in progress there. Lots of good comments though.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline
Old 07-04-2013, 05:10 PM   #8062
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I have been chasing an ignition issue for a while now and think I have it solved. I first replaced the module in the HEI and that didn't help. A buddy of mine gave me a whole dizzy and I dropped that in and problem solved. Now I need to buy one and give his back soon! Im just glad to have that solved.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline
Old 07-04-2013, 05:26 PM   #8063
mud.man.rj
mud.man.rj's Avatar
Was probably the picup coil in the distrib. The wires (2) wear out from moving back and forth being connected to the vacumn advance.
mud.man.rj is offline
Old 07-04-2013, 05:48 PM   #8064
Budman56
Budman56's Avatar
Happy 4th to every one!!!!
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline
Old 07-04-2013, 05:52 PM   #8065
Trsmotrhed
Trsmotrhed's Avatar
Thanks Budman, you too.
63 SWB C10
Old 07-04-2013, 09:32 PM   #8066
ACK
ACK's Avatar
Put in the HEI distributor yesterday. Painted the lifter covers and installed new gaskets this past weekend – no more little dots of oil up and down the driveway! The other thing I did was installed a solar cell system in the garage so there's now power for radio, power tools, shop lights for working on the truck after the sun goes down.
My truck ain't dead, it just smells funny.
ACK is offline
Old 07-04-2013, 10:10 PM   #8067
Acksman
Finished putting my Fatmat in today. Taped all the seams with 3M metal tape. Had a little friend give me a hand as well.
Next up tomorrow is trying to figure out how to install my new Flaming River tilt steering column. It will be interesting since I have not had a steering column in there for 10 years. I know I am missing a few pieces.
Acksman is offline
Old 07-04-2013, 10:46 PM   #8068
61_FL_Apache
Who Me?
Im looking into replacing the whole dizzy and eliminate any issues..
Steve
2001 Blazer 4D 2WD
Old 07-05-2013, 06:32 AM   #8069
Hx16457
Hx16457's Avatar
Changed plugs, and ran vacuum test to tune carburetor. I have it at 19 and solid. Reset timing and just plan tuned the engine to run, idle, and start better. Also swapped thermostat from 180^ to a 195^, trying to get her to run and burn fuel better. She seems to be running rich, so this is why I have gone down this road (above).
People who make excuses didn't want to do it in the first place!
http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16
Hx16457 is offline
Old 07-05-2013, 06:38 AM   #8070
Grizz1963
Grizz1963's Avatar
After work yesterday I raced about and took the truck, with Mickey my neighbour down to a local industrial estate to see if we could get the hole for the towball enlarged.
I had spoken to an engineering shop already who said bring it in after work, but he insisted we go try an old friend he had not seen a few years.
Got to where Raj had his shop before ..... Nothing. Turns out he moved a few years ago to much bigger premises less than a kilometer away.
Got there and the big guy was not there but "the boys" were impressed by the truck and prepared to give it a go (This is now after hours and Raj allows them to earn "a drink" (English term for a few pounds for a small odd job off the books, a bit like a tip)
Out came the Mag drill and some clamps along with a bit of 10mm steel plate. The drill has a strong electro magnet that allows it to effectively clamp onto the job and work as a pillar drill. With Mickey applying the cutting compound we soon had a 40mm hole for the 32mm bolt to fit through, yes I know, but a couple of heavy duty washers will sort that out. Everything still fits correctly.
Many hands make light work.
At this point Raj came back from a job site into the shop and if Mickey was a puppy he would have peed all over Raj's feet. They obviously have good friendship that has stood the test of time.
I gave the main operator £20 for a "drink" which he was very happy with. I believe in fairness and this will allow me to go back another day with some niggly job.
Job done.
After this I fetched my father in law after dropping Nicola off to look after mum.
Then we went to a car gathering where over 120 cars arrived.
Will post photos later elsewhere.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 07-05-2013, 07:05 AM   #8071
coulter
coulter's Avatar
mag drills are sweet!!!! thats a mean looking drill bit/ hole saw!!!
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline
Old 07-05-2013, 08:39 AM   #8072
DURG
DURG's Avatar
Some small incremental progress on the truck. I am trying to get everything that needs to be fabricated involving welding on the frame and chassis, so I can blow this thing apart and paint the frame and start reassy. I finished up the front bracing to the radiator support on both sides and finished up my Frankensteinish/Porter Built cross member/driveshaft loop. I need to scope out if I need to weld on the small clips that hold the end of the brakelines or if they will just pass thru the frame, other than that I don't think I have any more fab work to do but guarantee there will be something else. Always seem to need to remove new paint somewhere to weld on a project.
1962 Impala SS 383 stroker Tremec TKO 600 Black
1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black
2003 100th Anniversary Road King Classic Silver Black
DURG is offline
Old 07-05-2013, 11:10 AM   #8073
19666Trucker
19666Trucker's Avatar
you try some murry's mystery oil
19666Trucker is offline
Old 07-05-2013, 12:58 PM   #8074
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: What did you do to your truck today?
Project: "Full Metal Yellow Jacket" Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=321173
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline
Old 07-05-2013, 05:56 PM   #8075
cortcomp
cortcomp's Avatar
Wet sanded the non-white areas of the cab (overspray and primer) with 400 today to prepare for possibly laying the color + clear on tomorrow.
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline
Closed Thread
