replacement spring perch for dana 60
I bought a Chevy front dana 60 for my Blazer. The driver side spring perch is twisted and the holes blown out. I need to replace it. Anybody know of a replacement? The height of it is crucial as it needs to match the passenger side that is cast in the center section.
Josh Posted via Mobile Device |
Re: replacement spring perch for dana 60
Call dan at ruffstuff specialties.
Thanks for the lead. Sent them an email, if I don't hear from them by the time I get home from work tomorrow I will give them a call.
Ruff stuff couldn't help me. Anyone else?
I would think you could take a weld on perch, do some measuring, get the height as close to what you need, tack it, check it again if you really want to, and weld it on.
The problem is that your average weld on perch is not tall enough
Make one out of square tube. Make it as high as you want, up to the thickness of the tube. I think front springs are 3"? Mines not here to measure, but 3" tube also? Get a 3" hole saw and 3" square tube with 1/4" wall. Clamp a board to it for the pilot to drill into and make as high as you would like.
I know for a fact ruffstuff can do this for you. Did you talk to dan?
I talked to Stephen. He said they would not be able to make me one, but could sell me one of there standard ones for me to modify myself.
Try Barnes 4WD
1968 K10/30 Frame Off Project "Overkill" My 5 year, $30,000.00 toy |
To me it seems perches are essentially square tubing... although i could be wrong but here's an idea buy a piece of square tubing that is however wide you want the perch to be lets say 3in wide also you would have to get it at 1/4in thick. Now you have basically a full perch that hasn't been cut out so if the square tube was bought at 5in tall, 3in wide and 1/4in thick you could just make your own however tall then just notch it out for the axle tube. If all that makes any sense
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
Makes perfect sense to me!
Collector of Projects
Hmm. That sounds kind of familiar.
#15 |
The best way to get hold of diy4x is to call the shop. Ask for kurt. Id have a hard time believing he wouldnt make one for you.
#16 |
Diy4x list one for the Dana 60 front
http://diy4x.com/cart/index.php?rout...product_id=123 Posted via Mobile Device
