Closed Thread
Old 07-05-2013, 06:16 PM   #8076
markeb01
Senior Enthusiast
markeb01's Avatar
Re: What did you do to your truck today?
I really like the design of your front end support. I’ve seen many where the main heavy tube runs straight front to back against the firewall, and would seem to be rather dangerous for the occupants in a front end crash. Your design would absorb a lot of deflection rather than sending it into the cab. Beautiful workmanship.
Originally Posted by DURG View Post
Some small incremental progress on the truck. I am trying to get everything that needs to be fabricated involving welding on the frame and chassis, so I can blow this thing apart and paint the frame and start reassy. I finished up the front bracing to the radiator support on both sides and finished up my Frankensteinish/Porter Built cross member/driveshaft loop. I need to scope out if I need to weld on the small clips that hold the end of the brakelines or if they will just pass thru the frame, other than that I don't think I have any more fab work to do but guarantee there will be something else. Always seem to need to remove new paint somewhere to weld on a project.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 07-06-2013, 01:34 AM   #8077
BigDan3131
BigDan3131's Avatar
It finally stopped raining up here and it wasn't 90 plus so in about 3 hrs I hammered out two large dents, rough filled them with bondo-glass and shaped them back to stock. Fixed three rotted out holes and rough blocked the whole drivers side. Its surprisingly straight with just two little dings. Tomorrow I should have the drivers side done and ready for primer. The best part is when I lay the wire tape for the rhino it will end up sealing all of the repaired areas permanently. One other thing I decided to do is when I shoot the rhino is to shoot the roof section since there isn't a headliner and it will insulate the cab even more.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline
Old 07-06-2013, 05:54 PM   #8078
Grizz1963
Grizz1963's Avatar
Well I had Scott "Jabbo" over here today, he got called out to work last night, so had a quick few hours sleep this morning and then came over by 13.00
Scott had wired up the Grizz-Pod Teardrop Trailer a few years ago for me, I had a regular light board which he then wired up to the Taxi cab lights I fitted to the rear.
When it cam to wiring the truck for Euro lighting, I contacted Scott to ask if he was up for a bit of abuse..... to which he thankfully agreed.
I had cut and broken some of the driveway this morning and mixed a batch of concrete to redo the bits I had removed, just wrapping up when he got here.
Soon we had the truck out, and this was the view.
I decided to mount the plug under the load body, behind the bumper for looks and also to keep it safely tucked out of harms way, so this as the result.
My mate Peter "Goose" with whom I traveled in Europe on our bikes last year and his wife came down for an evening BBQ and sleep over as they wanted to join us for bootfair in the morning.
We found via Vernier caliper that the US Spec 2" chromed towball is about 1/2mm bigger than the UK Spec 50mm towball.
So he suggested stripping back the chrome to get it to fit securely into the trailer hitch.
Some time spent in the woodwork shed, gently sanding the ball on my linisher left us with a perfect fitting union.
Of course we needed to get some photos.
Scott and his family had recently moved to a new house and behind the shed he found this......
Seems I have a spare wheel rim now. Just need to get a tyre onto it. Thanks Buddy.
Next up I will clean and refurbish the rim.
That's all for now folks.
Bootfair in the morning.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 07-06-2013, 08:08 PM   #8079
mud.man.rj
mud.man.rj's Avatar
Good looking truck and trailer.
mud.man.rj is offline
Old 07-06-2013, 09:36 PM   #8080
cortcomp
cortcomp's Avatar
Got the green on the cab today after all day yesterday wetsanding the primer and white overspray down, and masking, cleaning, wiping, etc. It appears to have been worth it, i'm pleased with the results, especially since it was 80 degrees and 80% humidity for most of the paint job!
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline
Old 07-06-2013, 11:15 PM   #8081
Fastest32
Fastest32's Avatar
Fixed the front blinkers. Took apart the turn signal switch and found the contacts weren't even touching. Took em out and bent them a little to get them to touch and cleaned off the crud.
BaBaBooey BaBaBooey
GO SPURS GO!!!
Fastest32 is offline
Old 07-06-2013, 11:59 PM   #8082
Trsmotrhed
Trsmotrhed's Avatar
Installed my passenger rust free and straight door.
I'll install the drivers door tomorrow.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline
Old 07-07-2013, 12:48 AM   #8083
Grizz1963
Grizz1963's Avatar
Gotta be my favourite ever colour.
Was going to change our truck to that colour as well. But have decided to stick to red. ( Can always do it later)
Old 07-07-2013, 01:27 AM   #8084
russellmalcolm
russellmalcolm's Avatar
It's been a while since I posted anything, have been busy with work, family and my motorcycles (just picked up a new 07 HD springer!).
I finally finished up the dash and installed the stereo and got the clock working, also had the garage give me a clear coat finish for a good seal.
Decided to save money and not go with chroming the front grille, had my shop prime and paint it, I think it turned out well. Still having engine problems, not running as well as I would like, am going to get it checked out at a classic car garage in dubai as soon as they can fit me in.
Here are some pics from the recent work:
russellmalcolm is offline
Old 07-07-2013, 08:17 AM   #8085
JWheeler331
JWheeler331's Avatar
Finished redoing my dash cluster and hooked it all back up in the truck.
Still need to pick up a windshield wiper switch so I can get rid of the toggle switch that the previous owner put in there.
Also picked me up a couple of dash clusters that have all the gauges so I can start working on building one with the tachometer.
Had a little help from my newest member of the family.
JWheeler331 is offline
Old 07-07-2013, 08:20 AM   #8086
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: What did you do to your truck today?
More work on the Suicide Doors:
PROJECT: "FULL METAL YELLOW JACKET Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=321173
Suicide Door Engineering - 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck 5 - YouTube
https://www.youtube.com/watch?v=tYtOLi-2KbU
PROJECT: "FULL METAL YELLOW JACKET"
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline
Old 07-07-2013, 08:49 AM   #8087
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
No pics to show, but I got my distributor issue finally figured out.. A buddy of mine gave me a nice used GM unit so I thru on my new cap, rotor and module and its running like new again!!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline
Old 07-07-2013, 10:01 AM   #8088
Grizz1963
Grizz1963's Avatar
Bought a steel trunk for the truck......
Right, went to bootfair this morning with some friends who slept over last night.
Got lots of bits n bobs.
Then right at the end, last stall, there was a steel trunk.
Asked the price..... Got it for £10.00
Been looking for a trunk to bolt into the rear of the truck to act as seat at shows, safe box for tools, jack etc and another bit of "personal decoration" to add.
Brought it home and now have to decide what route to go.
Outside is completely rusted on the surface.
Inside has been painted at some point.
It also has "The Times of India" from 4th of July 1945 stuck in the bottom, fairly messed up, but we want to protect or keep it in there.
Advice needed please How do I keep the interior with the paper stuck to it in one piece and what way is the best for the outside?
My thoughts are clear varnish inside and clear lacquer on the outside with some pinstriping later when I can afford to have it done.
Latches are all brass.
Old 07-07-2013, 05:00 PM   #8089
JWheeler331
Sorry about moving the pics up above. Didn't know it would do that.
Here is everything again.
Old 07-07-2013, 08:00 PM   #8090
1964Chevy
1964Chevy's Avatar
Wednesday evening I took the seat and seat belts and shifter and vinyl out of the truck.
Thursday morning I started installing sound deadner and heat shield.
As is always the case with me, I started thinking.
A PO had installed an A/C that hung way down under the glove box. I removed all remnants of the heater (here in Texas there's not a lot of need for a heater) and saw that I could slide the A/C unit up behind the dash to hide it a little. I need to figure out if I can hook up hoses to distribute the A/C.
The Carpet arrived Friday and sits in the truck now.
Can't wait to drive it and hopefully notice a reduction in noise.....
Happy Birthday America, I love ya!!
If your strength is small, don't carry heavy burdens. If your words are worthless, don't give advice. Chinese Proverb
1964Chevy is offline
Old 07-07-2013, 10:49 PM   #8091
19666Trucker
19666Trucker's Avatar
Posted via Mobile Device cut coils to bring the nose down fill up the wheel well, wife asked if it was worth it. It always worth it.
19666Trucker is offline
Old 07-08-2013, 12:00 AM   #8092
mud.man.rj
mud.man.rj's Avatar
they just look so much better being lower.
Old 07-08-2013, 01:23 AM   #8093
lasher78
lasher78's Avatar
looks good...how does cutting the springs effect the ride vs. buying lowerd springs?
live like you are dying
lasher78 is offline
Old 07-08-2013, 02:50 AM   #8094
19666Trucker
So far on short on city street it did good, I got home made block 2" in the back. Thanks
Old 07-08-2013, 07:45 AM   #8095
bj383ss
bj383ss's Avatar
Put new shoes and socks on her!
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline
Old 07-08-2013, 08:04 AM   #8096
1964Chevy
1964Chevy's Avatar
bj383SS, looks great. What are the wheels and tire sizes that you have there? Also where did you buy them.
Old 07-08-2013, 08:15 AM   #8097
bj383ss
bj383ss's Avatar
Thanks 1964Chevy. They are 235/75 r15. I bought them from Coker tire. BFGoodrich Silvertown's They put a dent in my wallet but they really give the truck the hot rod look I was wanting.
I read good and bad reviews on Coker but most of the bad was from back around 2009 and I think they have gotten better. Most of the complaints were that the tires were out of round and the whitewall coming apart.
I bought a 5 year or treadlife warranty on each tire for $20. I get free replacement if the whitewall gets damaged or something happens to the tire. They pay for shipping it back as well. Just as good as Discount tires road hazard.
So far I have had not any problems I am very impressed as none of the wheels had to have weights put on them. Pretty impressive for 51 year old wheels. So obviously the tires are true as well.
The wheels are stock 62' Chevy 15x6 stock wheels I got from 62Barnfind.
It also rides real smooth and is much easier to turn now. I had 215/75's on 15x8 wheels. It was a bear to turn. The wife should have no trouble driving it now.
Can't wait to get it painted Satin Black!
Bret
bj383ss is offline
Old 07-08-2013, 09:04 AM   #8098
russellmalcolm
Bret, sweet looking ride. I have been thinking about painting mine a black satin or a gun metal grey, I look forward to seeing how yours looks. What you got under the hood? and How is it running?
Cheers.
Russell
Old 07-08-2013, 09:36 AM   #8099
bj383ss
bj383ss's Avatar
Thanks Russell. It has a stock 350 of unknown specs. Brother in law put in before it was parked. It has a 700r4 out of a 91 Camaro which I have read is one of the best ones. It runs real good. Has an HEI and Edelbrock carb. I only have one real bad picture of the engine when I first got the truck. I will take a better pic this evening. It is a mess under the hood haven't started on it yet.
Bret
bj383ss is offline
Old 07-08-2013, 02:46 PM   #8100
Grizz1963
Grizz1963's Avatar
Originally Posted by Grizz1963 View Post
Never sure how to respond.... a WOW that's Awesome is what sprang to mind.
Thank you very much for the offer.
I would love to replace by broken one once the paint has been done.
You have a PM as well.
Getting speedo/instrument binacle posted tomorrow. Thanks again.
Closed Thread
