Old 07-06-2013, 01:28 PM   #1
Dylan86
Dylan86's Avatar
472 Cadillac engine?
a 472 big block out of a 1969 cadillac coupe deville. Anyone heard good or bad things or dealt with these blocks? i might be buying one to build for my 86 c10? any thoughts or opinions?
Dylan86 is offline   Reply With Quote
Old 07-06-2013, 03:09 PM   #2
Metalshapes
Metalshapes's Avatar
Re: 472 Cadillac engine?
It is basically the same thing as the 500 caddy, heads, exterior componets will interchange. Be careful, if you put 472 heads on a 500 it yields somewhere in the neighborhood of 12.5 - 1 compression. Moving on, great engine, good availability of aftermarket parts and it is a torque monster, just think about what it came in.
Rally 'round the family....with a pocket full of shells.
Metalshapes is offline   Reply With Quote
Old 07-06-2013, 03:31 PM   #3
dieseldawg142
dieseldawg142's Avatar
these motors ARE torque monsters (check out the torque curve to 3000 rpm), & weigh a little more than a small block. my dad's friend has a '72 blaze with a 472, incredible seamless power.
http://www.500cid.com/ Maximum Torque Specialties
my dad,s friend says their the guru,s of caddy motors
dieseldawg142 is offline   Reply With Quote
Old 07-06-2013, 05:40 PM   #4
russgt
russgt's Avatar
A guy that I work with has a 472 cadi in a 79 Z28. It runs pretty good.
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 07-06-2013, 07:10 PM   #5
Ziegelsteinfaust
It is a great motor the torque is awesome stock, and only get better with bolt-ons. Throw in a modern cam, and they will just about hang with many diesels when towing.
I have seen them used in a few trucks, but you need the lowest gears to make the package work its best.
In my C20 with 32" tires a fresh 350 with 3.73 gears, and no overdrive is a nice combo.
On a 472/500 Cad I would look for a Dana 61 with 3.07 gears, and it would probably still light up the tires.
Ziegelsteinfaust is offline   Reply With Quote
Old 07-06-2013, 07:49 PM   #6
mrolds88
One other thing that you need to know. The RWD oil pan won't work on your truck. Swap an Eldorado pan and you will be good to go. They are torque monsters, just don't over rev them.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 07-06-2013, 10:20 PM   #7
Low84
Low84's Avatar
It's been a good engine to me thus far. Not really a gas saver but it gets me better gas mileage on this with the hydraulics and spokes than my stock 6.0 2500hd.
My father in law has a 500 in his Caddy and that has been a good engine as well as far as I know
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265
Low84 is offline   Reply With Quote
Old 07-06-2013, 11:57 PM   #8
manimal
manimal's Avatar
Longhornman had a 500 in his 69 longhorn. I have not seen him here in a VERY long time. Also there was a 60-66 at Brother's Show and Shine that had a caddy in it. Was pretty cool!
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 07-07-2013, 01:11 AM   #9
rcrahn
rcrahn's Avatar
My next door neighbor has a friend with a Caddy engine in his squarebody. I saw it breifly and heard it run. It is sic.... A torque monster is right...
rcrahn is offline   Reply With Quote
Old 07-07-2013, 05:28 AM   #10
Low84
Low84's Avatar
^^ That is a clean truck! What wheels are those?
Old 07-07-2013, 08:01 AM   #11
Hertzdaddy
I have a 500 in my Jimmy 2wd. Love it. Its been modded a bit and puts out around 500hp and 600tq. I'm using the oil pan from the later 425 rwd cars, commonly referred to as the mid sump. It fits fine and can be had for less than the Eldon pan.
Hertzdaddy is offline   Reply With Quote
Old 07-07-2013, 08:33 AM   #12
hatzie
Moderator
hatzie's Avatar
A fellow I worked with in LA had a 472 in a 77 GMC K20. Got mid teens for fuel mileage with a Rochester quadrabogger... I never asked how he fitted the SM465 to that motor. It's a BOP bellhousing pattern but I bet it was fun to source the flywheel.
He said it towed a 28' Airstream everywhere and it ran up the Grapevine towing it like it didn't have anything in tow.
You'll need a rear sump Eldorado oil pan. If you have 2wd drop it in with a Caddy TH200R4 and mod the driveshaft.
Damn nice to have the distributor up front like my 383 Polara.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-07-2013, 08:37 AM   #13
hatzie
Moderator
hatzie's Avatar
That's gorgeous.
Old 07-07-2013, 10:39 AM   #14
gmachinz
The only issue the 472/500 motors had is in the oiling system-the wide main bearings soak up a lot of heat and tend to score a bit by the time you get to 60K and up.....but, a quality overhaul using Clevite Tri-Metal bearings will help a lot-I would recommend lightening up the stock crank while at the machine shop and paying extra for balancing the rotating assembly to +/- 3 grams.....that'll help ensure the heavy rotating assembly won't tear up the bearings much.....obviously synthetic oil wasn't a luxury those old Caddy motors originally could have taken advantage of but they can now-that too will help extend its life. For the record, in 1970 the 500 motors were rated the highest in stock form-375 HP and 500 FT!
gmachinz is offline   Reply With Quote
Old 07-07-2013, 12:30 PM   #15
Ziegelsteinfaust
What about adding some room in the pan for a few more quarts.
When I do up my truck engine in my c20 no matter how wild to basic. I will mod the stock pan for about 3-4 extra quarts.
Old 07-07-2013, 07:18 PM   #16
74 stepside
74 stepside's Avatar
Heres a 500 ci caddy in a 61 C10 that was at Brothers show. I love it, because its different.
74 stepside is offline   Reply With Quote
Old 07-07-2013, 08:44 PM   #17
gmachinz
Nice....that's a gorgeous engine bay! 500/472 Caddy motors are definitely sexy lookin!
Old 07-07-2013, 09:33 PM   #18
Dylan86
Dylan86's Avatar
Thanks! do you know if i am going to need to bulk up the frame at all, or cooling system? what about engine mounts? any other mods that need to be done to go from a 350 small block?
Old 07-07-2013, 11:45 PM   #19
2ndstoryslam
2ndstoryslam's Avatar
Your 3-4 core radiator should do. Frame is fine, remember its weight is a little more than a SBC. An Edelbrock intake will add mucho to the scene, and lighten the weight as well.
2ndstoryslam is offline   Reply With Quote
Old 07-08-2013, 12:44 AM   #20
manimal
manimal's Avatar
got some pics? I would like to see the frame area near the exhaust manifolds....Did you have to clearance the frame at all?
-Lance
Old 07-08-2013, 12:45 AM   #21
manimal
manimal's Avatar
That's the one I mentioned earlier! Thanks Matt!
-Lance
Old 07-08-2013, 04:04 PM   #22
1981Sturgis
1981Sturgis's Avatar
500 Cad in my Crew cab
1981Sturgis is offline   Reply With Quote
Old 07-08-2013, 06:17 PM   #23
Hertzdaddy
Here ya go.
No clearancing is necessary with manifolds. Some slight clearancing was necessary with BBC truck headers modified for the Caddy engine.
A typical installation like mine involves moving the frame mounts forward to match up with Caddy 425 engine mounts from '77 era rwd cars. That gives plenty of room to route the exhaust from the manifolds (or headers) down. Frame mounts have to be cut to clear the steering center link rod and a new hole drilled in the crossmember to attach the frame mounts (just one is used).
Another method leaves the frame mounts in place and uses a 1/4" spacer plate to extend forward to Eldorado stud-style mounts. Either method works fine.
Old 07-08-2013, 06:32 PM   #24
Hertzdaddy
Some more oil won't hurt but that's not really the problem. The design uses up most of the oil before it hits all of the bearings. Go hear for a lengthy discussion http://www.cadillacpower.com/forum/v...5265&start=140
Old 07-08-2013, 11:11 PM   #25
Dylan86
Dylan86's Avatar
Picked her up today! cant wait to build her pretty and go threw tires like i will gas!
