Old 11-28-2003, 06:43 PM   #1
fast14
fast14's Avatar
Cool Does this piece exist???
Hello all, i'm new here. I have been trying to find out if there was ever a flat style front yoke made for a 10 spline np-205 transfer case that I have in my 70 chevy 4x4. I have the regular yoke on it now but I have a brand new driveshaft with the flat flange on it and I would rather use that style. Any help will be appreciated.
Just a little crazy
1970 chevy full size half ton, soon to be one ton running gear, 350 turbo, 205 case, 355c.i.
fast14 is offline   Reply With Quote
Old 11-28-2003, 06:52 PM   #2
Johns70
Johns70's Avatar
I think you need a newer style yoke from a 75 newer chevy truck.
69 chevy short wide box project
70 GMC jimmy project
Johns70 is offline   Reply With Quote
Old 11-28-2003, 06:54 PM   #3
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Yes they do exsist. I have one on the front of my 205 transfer case that was removed from a 1978 1 ton 4X4. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 11-28-2003, 06:54 PM   #4
fast14
fast14's Avatar
Well, i've got two yokes from newer trucks that have the flat flange but they are fine splined. My old yoke has 10 course splines.
Just a little crazy
Old 11-28-2003, 06:55 PM   #5
Classic Heartbeat
Hey John, did you see I got your truck uploaded onto our client's pics page? How does everything look? WES www.ClassicHeartbeat.com
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 11-28-2003, 06:55 PM   #6
fast14
fast14's Avatar
WES, so you hae a 10 spline flat style yoke??
Just a little crazy
Old 11-28-2003, 06:57 PM   #7
Classic Heartbeat
Were the yokes removed from trucks that were standard transmission trucks?.. I haven't pulled my yoke off yet to see how many splines it has. WES www.ClassicHeartbeat.com
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 11-28-2003, 07:03 PM   #8
fast14
fast14's Avatar
I honestly don't know what they came off of. According to this link, http://www.bowtiecrawler.com/NP205.html , the 10 spline course input shafts were found mostly on applications with manual transmissions but my truck came factory with a 350 turbo and it's got the course splines on it. The main reason I want to switch is for ease of working on. It bites having to tighten the fine threaded bolts up on a cv joint when you can only get about an 8th of a turn on each try because of having to tighten from the back side of the yoke.
Just a little crazy
Old 11-29-2003, 01:51 AM   #9
72 CustomCamper
huh ???
72 CustomCamper's Avatar
The shafts that are shown on that site is where the T case is connected to the trans. From what I'm reading of your post is that you want where the T case is connected to the front drive shaft. Which would be the front output shaft. In that case the spline count should be the same through the years...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 11-29-2003, 01:55 AM   #10
fast14
fast14's Avatar
Yeah I realized they were talking about the input shaft threads. I think there are 10 spline and like 30 spline front output shafts though. A buddy of mine has a 205 with splines that are completely different than mine. Anybody know of an aftermarket company I might check with or a website?? Thanks.
Just a little crazy
Old 11-29-2003, 02:31 AM   #11
72 CustomCamper
huh ???
You might want to give Advance adaptors a try. Seems like they have a little bit of everything...
Chuck
Old 11-29-2003, 02:46 AM   #12
fast14
fast14's Avatar
I think they have a lot of toyota stuff and not much full size stuff.
Just a little crazy
Old 11-29-2003, 03:19 AM   #13
Scrub
Collector of rusty Items
Scrub's Avatar
There is a 205 on e-bay right now that has what I belive is a 10 spline output shaft with a flange. THe guy says it came out of a Chevy with a 235? 4 speed.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2445066376
Good luck
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 11-29-2003, 03:22 AM   #14
fast14
fast14's Avatar
Thats the piece i'm looking for but i can't tell if it's a course or fine splined case.
Just a little crazy
Old 11-29-2003, 03:40 AM   #15
fast14
fast14's Avatar
If it works here is a pic of what the splines look like in the yoke i took off.
Just a little crazy
Old 11-29-2003, 03:46 AM   #16
fast14
fast14's Avatar
And here is a not so good pic of the piece i thought would work. You can tell the splines are completely different.
Just a little crazy
Old 11-29-2003, 02:28 PM   #17
Scrub
Scrub's Avatar
The first is a ten spline that is on most 205 t-cases. The seond is a 32 spline. 32 spline front outputs are on 205 t-cases that are behind a Turbo 400. You can also find them on a Dodge t-case. You can change any 205 to a 32 spline output if you have the parts. You may want to do that anyway as it is much stronger.
I think I just saw those parts on ebay.
The bolt pattern on the t400 part is different from the pattern on the t-case that I showed you on ebay. Both of them are different from the one in your second picture. Make sure your driveline matches the flange.
What are the dimensions of the flange on your new driveline?
High angle driveline makes a flanged frone output, but it fits a 32 spline.
FYI the part in the second pic is worth about 50 bucks.
Good luck
Scrub
Old 11-29-2003, 03:03 PM   #18
Scrub
Scrub's Avatar
I wonder if this would fit?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2444835154
Scrub
Old 11-29-2003, 06:50 PM   #19
OLDCHEV4X4
OLDCHEV4X4's Avatar
Wouldn't the flat flange hit the crossmember on a 72?
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 11-29-2003, 07:29 PM   #20
fast14
fast14's Avatar
Well I haven't gotten far enough to figure out if it would hit or not. I hadn't thought about that though. The second piece is worth about 50 bucks huh?? I have two of them!! LOL That piece on that e-bay link looks almost like the right splines but it's hard to tell if the od is the same.
Just a little crazy
