Old 07-07-2013, 08:21 PM   #1
BigRed76
BigRed76's Avatar
1967-71 Door Panel Skins
Has anyone ever put new repro door panel skins on plain steel 67-71 door panels?
How do they attach to the door panels?
Is it a real pain or something that is pretty doable?
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 07-10-2013, 03:56 PM   #2
BigRed76
BigRed76's Avatar
Re: 1967-71 Door Panel Skins
Anyone ever dealt with this?
Zach
Old 07-10-2013, 05:00 PM   #3
72bowtiestepper
Are you asking about outer door panel skins ? (the outside of the door) If so, then yes I have....plan on replacing the door bottoms at the same time. Patch panels are available.
72bowtiestepper is offline   Reply With Quote
Old 07-10-2013, 05:10 PM   #4
Bigdav160
Bigdav160's Avatar
I'm going to reskin my passenger door.
My plan is to use panel adhesive so to get the body lines aligned correctly.
I'm still researching the best method to fold and crimp the edges.
edit:
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-10-2013, 06:08 PM   #5
GMCPaul
Its very easy in my opinion to apply the interior door panel vinyl skins to the steel door panels. Thoroughly clean the original door panels and wipe down with acetone or similar product. You use a spray on vinyl adhesive on both and then lay the skin on the steel door panel aligning the holes for regulator and door relay while smoothing it out ( I use a small paint roller to roll over the door skin applying pressure), there is enough material to comfortably fold it over the edge wrapping onto the back ( Be sure to apply adhesive around the back edges of the door panel skin where its folded over onto the back ).
Paul @ GMCPauls
GMCPaul is offline   Reply With Quote
Old 07-10-2013, 06:30 PM   #6
Bigdav160
Bigdav160's Avatar
, ignore my post.
door panel skins, not door skins
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 07-10-2013, 06:46 PM   #7
Bigdav160
Bigdav160's Avatar
ouble post :please delete:
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 07-10-2013, 09:47 PM   #8
BigRed76
BigRed76's Avatar
Yes I'm talking about the vinyl pieces on the inner door panels sorry for the confusion.
The door panels in my '71 are just the plain painted panels and I'd like to upgrade them. But I do have a set of olive green deluxe panels from a '70. Would it be easier to just paint the green ones? Is there a paint that will stick well to the vinyl?
Zach
Old 07-11-2013, 06:59 AM   #9
GMCPaul
They do make a vinyl paint but I've never had good luck with color lasting. You might speak with a local upholstery shop on what they may charge to change the color on the green version you have.
Paul @ GMCPauls
Old 07-11-2013, 08:26 AM   #10
D.PASSMORE
One of the First
D.PASSMORE's Avatar
I have used finishmaster automotive interior paint with great sucess. It is pricey but very durable. Find a Finishmaster near you and they should be able to help you out.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 07-11-2013, 11:29 AM   #11
Mayo
Cool Truck
Mayo's Avatar
I reskinned my door panels back in the spring and it went pretty good. I had the edges bunched up a little bit so they were a little tough going back in the door.
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 07-16-2013, 12:11 AM   #12
BigRed76
BigRed76's Avatar
Think I might try this on my green panels and see how it works since this paint is pretty easy to get.
https://www.rustoleum.com/CBGProduct.asp?pid=370
Zach
Old 07-16-2013, 09:10 AM   #13
DaHos
DaHos's Avatar
While were on the subject, anyome have experance with repo skins, quality etc.....
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 07-16-2013, 09:37 AM   #14
Mayo
Cool Truck
Mayo's Avatar
I bought my repro skins about a year ago but just put them in back in March or April. I got the black ones from Brothers I believe and they are really nice quality if you ask me. They were easy to install but there were about 4 legs on each one I had to cut off to get the edges to sit flush. I am really happy with the product and it looks much better than driving without door panels.
Old 11-22-2017, 01:54 PM   #15
elf w/capital T
So the skins can just be glued to the metal door panel piece?i see pre-assembled for 180, and just the skins for 110... i have the metal door panel, just no upholstery
elf w/capital T is offline   Reply With Quote
