Old 07-07-2013, 09:18 PM   #1
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Anyone have OEM Auxiliary Battery (RPO TP2) or Rear Seat Center Belt (RPO A68)?
Would like to see SPIDs and/or photos of Blazers w aux batteries or rear seat center belts. Did 72 K5's w a rear seat come standard with two belts? Thanks, Pete
Old 07-07-2013, 09:48 PM   #2
JimH2828
Re: Anyone have OEM Auxiliary Battery (RPO TP2) or Rear Seat Center Belt (RPO A68)?
While trying to identify correct duel horn setup, I ran into this post that had a picture of an aux battery tray. Thought it would help ya.
http://67-72chevytrucks.com/vboard/s...=horn+location
-Jim
JimH2828 is offline   Reply With Quote
Old 07-07-2013, 11:18 PM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
-Jim
Thanks! I have an aux battery in my K20 - wanted to confirm that K5's could also be so equipped from GM...
Old 07-07-2013, 11:56 PM   #4
markedgar5
markedgar5's Avatar
I have an aux tray as well. Pm for pic if needed
markedgar5 is offline   Reply With Quote
Old 07-08-2013, 06:43 AM   #5
jaros44sr
jaros44sr's Avatar
Do you have a pic. of where the relay is mounted on the inner fender. Just bought a set up from Koop and not sure where it is mounted up....thanx
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is online now   Reply With Quote
Old 07-08-2013, 08:16 AM   #6
DeadheadNM
Carpe manana
DeadheadNM's Avatar
The relay doesn't mount to the inner fender in the OEM set up. It mounts to either the tray or rad support - can't remember exactly which but certain it isn't the inner fender. I'll see where we mounted the relay on my K20. Here's a pic that shows the J-block on the fender:
Old 07-08-2013, 06:30 PM   #7
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
If I remember correctly, it mounts to the core support, next to the regulator. If I had my assembly manual, I would look it up for you, but its at home...
That is where I put mine when I installed the aux battery.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 07-08-2013, 08:45 PM   #8
jaros44sr
jaros44sr's Avatar
Thanks guys for the tips....ill check out my manual
SAFETY FIRST
AS usual, off topic
Jim
Old 07-08-2013, 09:33 PM   #9
Mike C
Mike C's Avatar
My '72 Jimmy had the center rear belt, but it was not on the SPID. It had AM/FM and cruise control, and that was not on the SPID either. We got it used in '77 so previous owner may have had dealer add?
It has aux batt tray now, but I added that.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 07-09-2013, 12:30 PM   #10
jaros44sr
jaros44sr's Avatar
Just looked at the aux. tray, does have holes in the side, but none seem to line up exactly for the relay
SAFETY FIRST
AS usual, off topic
Jim
Old 07-09-2013, 12:41 PM   #11
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Those holes are for the voltage regulator and originally had rubber grommet inserts....
Old 07-09-2013, 12:44 PM   #12
skorpioskorpio
I had (have been since sold) the center rear belt as well as front and rear shoulder belts, on the SPID as 4A85AG.
skorpioskorpio is offline   Reply With Quote
Old 07-11-2013, 11:04 AM   #13
jaros44sr
jaros44sr's Avatar
Dam, youre right, it does fit there! Now i just have to buy the isolaters
SAFETY FIRST
AS usual, off topic
Jim
Old 07-12-2013, 06:20 PM   #14
DeadheadNM
Carpe manana
DeadheadNM's Avatar
So my 72 K5 has a center rear seat belt but this isn't listed on the SPID. Did all 72's w a rear seat get a center belt?
