Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-07-2013, 08:58 PM   #1
Blue Rat
Putting fuel tank in the back thoughts.
I have looked at options looked at past threads til I am blue in the face. So what are you using an seems to be the best option? I want to move the tank to the rear in front of the rear bumper.
1971 C10 Short wheel base.
Blue Rat is offline   Reply With Quote
Old 07-07-2013, 09:28 PM   #2
Ironhorse
Ironhorse's Avatar
Re: Putting fuel tank in the back thoughts.
When I moved my tank to under the bed in my '71 long bed 4x4 I got my tank, straps and sending unit from GMC Paul, board member and supporting vendor. May not be "the best" option out there, worked well for me, but "best" is rather a subjective term. I went with the poly tank and have had no problems at all. Opened up a lot of storage space behind the seat and more weight on rear axle in winter time is nice plus. Lots of tank filler ideas out there. What works best for you with your experience, $$, time and desired outcome is also subjective. Good luck with your decision.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 07-08-2013, 10:13 AM   #3
Domer
Domer's Avatar
Im running a 20+ gal fuel cell built to fit between my rear rails.. filler is straight through the bed floor.
Domer is offline   Reply With Quote
Old 07-19-2013, 07:55 PM   #4
Blue Rat
Ordered my tank early this morning Domer.
Old 07-20-2013, 08:09 PM   #5
roughedup72
roughedup72's Avatar
Mine is a 72 blazer tank and straps, used a 84ish style fuel door and neck. looks nice and clean but did have to fabricate a little on the inside of the bed to make a box for the fuel neck. I thought I had some pics of it on this computer but must not. You may have already seen it though. Good luck, There is a lot of great Ideas here, you just have to go with the one you like best.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod.
roughedup72 is offline   Reply With Quote
Old 07-20-2013, 11:38 PM   #6
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
Boyd Welding is a forum sponsor and makes a beautiful Al tanks for 67-72 trucks.
http://www.boydwelding.com/products/...evy-truck-tank
-Automatics win races, 6-speeds impress high school kids
-Save a tree, support your local dragstrip.
-"Failure - The Secret To Success, the idea is that you can fail 100 times as long as you can succeed once" -Takeo Fukui
columbuscarsandcoffee.net and on Facebook
ProStreet68SB is offline   Reply With Quote
Old 07-28-2013, 11:54 PM   #7
Bad70sbchevy
Bad70sbchevy's Avatar
I'm kind of partial to the 1969 Camaro Gas Tank swap
http://67-72chevytrucks.com/vboard/s...d.php?t=448431
1970 Chevrolet C-10 w/355sbc
2010 Silverado Daily Driver
1971 Mercedes 280sl project car
Bad70sbchevy is offline   Reply With Quote
